Ray Heath Jr
    6
Everything posted by Ray Heath Jr
  1. Reboot your radio, it will come back. Turn off the car, open the door, let the radio go black, wait 10-30 seconds, and turn it back on. Nav should work after a 30 or so seconds.
  2. My bad! Clarity is good, because there seems to be A LOT of bad info flying around.
  3. Nope! AA requires only the software update. CP requires the upgraded hub on 15's and most 16's. Both require USB connection to work. See this thread...it is JMR01 that built the files that BrianG is referencing above. http://www.fordedgeforum.com/topic/21394-sync-3-and-carplayandroid-auto-information/ There are several Mirrors in the thread. Here are the Mirrors I have up: NAV: https://www.amazon.com/clouddrive/share/zSuZOEIFitgLsSCTBIApCsTImfquM3Hhf4wUxk8aY54? Non-NAV https://www.amazon.com/clouddrive/share/sFmhYxZZDP8cK6m0OomrZxAbgi7pUEM5BLCGDk7mvzS?
  4. You should have bought GJ7Z-19A387-B like JMR mentions in the first Post in this thread. Why did you order something different than what he mentioned? It is Apple certified, that is the difference. Won't see the CP button without the Certified hub.
  5. Yes, mistype, and was covered many posts ago. The 2 current updates are 1.6GB(Nav) and 2.2GB(Non-NAV)
  6. Searched for the Part number on Ebay that JMR mentioned in the first post in this thread, and bought it. Couple online Ford Parts places had it in stock also when I looked. I had dealt with the EBay seller before, so I went back there.
  7. The issue is the Hub in the 2016 and 2015's is not Apple certified. It works with AA out of the box, the people that want to use CP have to swap the Hub. Have one on order.
  8. NAV: https://www.amazon.com/clouddrive/share/zSuZOEIFitgLsSCTBIApCsTImfquM3Hhf4wUxk8aY54? Non-NAV https://www.amazon.com/clouddrive/share/sFmhYxZZDP8cK6m0OomrZxAbgi7pUEM5BLCGDk7mvzS?
  9. https://www.amazon.com/clouddrive/share/zSuZOEIFitgLsSCTBIApCsTImfquM3Hhf4wUxk8aY54? Here is a link for the NAV version...I will get a similar link for Non-Nav once I can get the file from JMR.
  10. Thanks for the replies on the Wife's accident! She is sore but OK. Working on some additional Mirrors that won't be limited.
  11. Since this is an Edge Forum, and we are a smaller group, most likely not. With that said, JMR01 did his initial testing on a bench. The Sync units are the same across the product line. So most likely it will work. Again, you own risk.
  12. One more download link! Sorry for going dark after initial testing. This is what I have been dealing with the last 24: Wife had somebody turn left in her path on the way home from work. Her Expy did it's job, and she walked away just sore. Couldn't be more thankful Ford built a safe Vehicle! She was doing 45. Think Ford tweaked the speed on the recent update, and response is good. The Text receive screen is different, and has less options.
  13. First impressions, voice command is more responsive and the voice has changed. It doesn't go on and on any more when you mess up the command. Update went great. Put the drive in when I was leaving work, because I have a 30 minute commute. About 20-25 in said it was done. Next Car restart in the driveway it finished. Took a bit for it to load the Map after, then all good.
  14. That link is for 2 speakers, isn't there only one in the dash?
  15. THANKS for the work on this! Guys, I will have it installed today. JMR and I got crossed on what file I needed, so downloading the file I actually need right now. With his permission, I will also post it on a faster download location and publish. I have NAV. But since I already downloaded the Non-Nav, I can put it in a few locations for download that will be faster. I have options, personal server, Amazon, and Google. Have practically unlimited space on all. I will see if I notice any non AA/CP changes. I have the USB hub on order. Should have it later this week, hopefully get it installed this weekend so I can play with CP.
  16. If you have the heated steering wheel it warms automatically also. Works great on mine!
  17. So, it was the compressor. They should have it ready Monday.
  18. Thanks guys! Leaning towards the coolant being low. Played with it last night, after putting stock program back on ECU. It try's to adjust based on the set temp, so I think the sensor is good. Just think it's not cooling.
