Thermostat on a 08 Edge
Dean Bryant
  • 2 years later...
Item Part Number Description
1 W500014 Thermostat housing cover bolt (2 required)
2 8594 Thermostat housing cover
3 — O-ring seal
4 8575 Thermostat
1 8W005 Vent hose
2 8B273 Lower radiator hose
3 8B274 Upper radiator hose
4 18K580 Heater core outlet hose
5 18K579 Heater core inlet hose
6 W503279 Thermostat housing bolt (3 required)
7 8565 O-ring seal
8 8A571 O-ring seal
9 8A587 Thermostat housing
Removal and Installation
  1. Drain the cooling system. For additional information, refer to Cooling System Draining, Filling and Bleeding in this section.
  1. Remove the air cleaner assembly and outlet pipe. For additional information, refer to Section 303-12 .
  1. Remove the 2 bolts and position aside the thermostat housing cover.
    • To install, tighten to 10 Nm (89 lb-in).
  1. Remove the O-ring seal and thermostat.
    • Clean and inspect the O-ring seal. Install a new seal if necessary.
  1. NOTE: Lubricate the thermostat O-ring seal with clean engine coolant.
    To install, reverse the removal procedure.
  1. Fill and bleed the cooling system. For additional information, refer to Cooling System Draining, Filling and Bleeding in this section.
Edited by WWWPerfA_ZN0W
