gccch Posted February 16, 2014 Report Share Posted February 16, 2014 We have a 2010 MKX. When switching drivers, the memory settings sends the mirror into a continuous drive to one side, as if you are holding the mirror adjustment knob far left or right until it clicks. But it continues to click and does not go to the programmed position. We have tried reprogramming several times. Is there a way to reset this system? Quote Link to comment Share on other sites More sharing options...
Haz Posted February 17, 2014 Report Share Posted February 17, 2014 (edited) According to these similar past discussions, you may be needing to replace the mirror motor assembly... http://www.fordedgeforum.com/topic/12036-side-mirror-memory-position/ http://www.fordedgeforum.com/topic/13410-memory-mirror-not-working-properly/ If you are considering doing it yourself, the method for removing the mirror glass to gain access to the mirror motor is discussed here... http://www.fordedgeforum.com/topic/4892-how-to-replace-side-mirror/ Good luck! Edited February 17, 2014 by Haz Quote Link to comment Share on other sites More sharing options...
gccch Posted February 17, 2014 Author Report Share Posted February 17, 2014 Thank you HAZ, Great guidance. Greg Quote Link to comment Share on other sites More sharing options...
