scootewr1184 Posted September 10, 2014 Report Share Posted September 10, 2014 I recently upgraded to the factory nav and replace the switch in the steering wheel. Now all the phone button does is answer a call and redial. I've tried holding it down. I've tried double tapping it. I've tried just tapping it once. Only does redial. Before upgrade it would go to phone, hang up phone and answer phone. I've also done a master reset. Does anyone know about this? Do I need to upgrade my softwhere? Quote Link to comment Share on other sites More sharing options...
brettbolt Posted September 11, 2014 Report Share Posted September 11, 2014 I don't know the answer to your question, but how did you upgrade to factory NAV? My 2013 Edge SEL has MyFord Touch and I would like to upgrade to factory NAV too. Also, how much did it cost? Thanks. Quote Link to comment Share on other sites More sharing options...
gary712 Posted September 11, 2014 Report Share Posted September 11, 2014 besides changing the steering wheel switch you have to rewire the switch. also you have add wiring to the sync module. Quote Link to comment Share on other sites More sharing options...
akirby Posted September 11, 2014 Report Share Posted September 11, 2014 That was a 2008 non-MFT system. You could simply swap out the head unit for a nav and it works. You can't do that on 2011+ models with MFT. Quote Link to comment Share on other sites More sharing options...
brettbolt Posted September 11, 2014 Report Share Posted September 11, 2014 (edited) That was a 2008 non-MFT system. You could simply swap out the head unit for a nav and it works. You can't do that on 2011+ models with MFT. Thanks for the reply. So I guess the only option is to use a portable Garmin if I want NAV in my 2013 with MFT. Edited September 11, 2014 by brettbolt Quote Link to comment Share on other sites More sharing options...
Waldo Posted September 11, 2014 Report Share Posted September 11, 2014 To the OP, I suspect you need to reconfigure the settings in the Sync module. But this isn't something you can do without a dealer diagnostic tool, and even then it's not something dealer's are trained to do. Quote Link to comment Share on other sites More sharing options...
TheWizard Posted September 11, 2014 Report Share Posted September 11, 2014 I don't know the answer to your question, but how did you upgrade to factory NAV? My 2013 Edge SEL has MyFord Touch and I would like to upgrade to factory NAV too. Also, how much did it cost? Thanks. There are several products that allow you to replace the factory head unit with an aftermarket one having navigation (Kenwood, Pioneer, etc.) but in your case the best option might be the Intraphex GPS Navigation system which integrates navigation into your MFT equipped Edge using the existing factory 8" screen. http://www.intraphex.com/portfolio/ford-navigation/ http://www.autofixinfo.com/IkEA4HoWFIM7F4/2013-FORD-EDGE-INTRAPHEX-GPS-NAVIGATION-SYSTEM.html Neither site has pricing posted so I have no idea how much it costs but it sure looks like an interesting product. 1 Quote Link to comment Share on other sites More sharing options...
wlepse Posted September 12, 2014 Report Share Posted September 12, 2014 Thanks for the reply. So I guess the only option is to use a portable Garmin if I want NAV in my 2013 with MFT. Think you are better off with that or using your phone. I find the OEM Nav to be terrible. Sometimes it can't locate me for a while and most routes it picks are questionable. I pretty much only use my phone now since it is so unreliable. Quote Link to comment Share on other sites More sharing options...
