code p2272
bapierce
Hi my CEL came one a week ago and pulled the code p2272 which is o2 sensor bank 2 sensor 2 running lean. So I replaced the sensor with a o2 that was for the upstream that I had. The CEL came back on after replacing it. My question is are both the upstream and downstream o2 sensors the same sensor or are they not interchangeable? If they are I'll probably be replacing my catalytic converter next sence I can't find anything else wrong.
Edited by bapierce
They are different, at least going by P/Ns and pricing.
MOTORCRAFT Part # DY1056 Downstream
MOTORCRAFT Part # DY1064 Upstream
NTK Part # 22046 Upstream (OEM)
NTK Part # 22500 Downstream (OEM)
There is a possibility that the sensors are identical but used in different ways by the ECU, or that wiring length is the only difference (clearance), but I wouldn't take that chance. Are you still under the emissions warranty?
Edited by WWWPerfA_ZN0W
