pawnman001 Posted October 7, 2014 Report Share Posted October 7, 2014 How difficult is it to change the fuel pump on a 2008 Ford Edge? Quote Link to comment Share on other sites More sharing options...
Camshaft Posted October 22, 2014 Report Share Posted October 22, 2014 (edited) Have the fuel at 3/4 of a tank or less. Remove the rear seat and access cover. You need a special wrench or something to remove the lock nut on the fuel pump module. Lift out carefully and remove the fuel jumper tube on the inside.(AWD models) Then voila. So pretty easy if you have the right tools. Edited October 22, 2014 by Camshaft 1 Quote Link to comment Share on other sites More sharing options...
EDST777 Posted August 18, 2023 Report Share Posted August 18, 2023 Hello. How often do you need to change the AWD 2008 fuel pump, what is its resource from statistics on statistics? Quote Link to comment Share on other sites More sharing options...
