Rear Bearing Replacement Help
Hello all. I have been searching most of the day for a solution to my problem and haven't been able to find one so here I am.
We have been experiencing increasing noise from the rear of our 2007 Edge SEL FWD (120K+ miles). I've investigated for quite some time and with the help of a few previous forum posts concluded that the rear bearings have begun to fail.
I started on the passenger side as that is where I suspect most of the noise is coming from. I have the wheel off; brake caliper, pad, rotor, and slide removed. I removed the 4 T-60 torx screws from the back of the hub and used a slide hammer to remove the hub from the knuckle. What I wasn't expecting was that the entire hub, dust shield, and parking brake came with it when it finally released. There has been pretty significant corrosion to the back side of the bearing assembly and it is locked into the hub plate (at least that's what I'm calling it). For the life of me, I have not been able to free the bearing from the hub plate/parking brake assembly.
Any suggestions on how to get these seperated? Unfortunately, I can't really see a good way to press these out.
Not sure how tohelp here, near I can figure is you need to get the brake caliper support plate off the assembly? Hub & bearing are integral, replaced as one unit.
Brake Disc Shield
Item Part Number Description
1 — Parking brake shoe return spring bracket bolt
2 — Parking brake shoe return spring bracket
3 2K045 RH/ 2K046 LH Brake disc shield
Removal and Installation
  1. Remove the wheel hub. For additional information, refer to Section 204-02 .
  1. Remove the parking brake shoe return spring bracket bolt and bracket.
    • To install, tighten to 5 Nm (44 lb-in).
  1. Remove the brake disc shield.
  1. To install, reverse the removal procedure.
Brake Caliper Support Plate
1 2C220 Brake caliper support plate
2 — Dust boot
3 — Dust boot shield
4 — Dust boot shield bolt (2 required)
5 2A635 LH/ 2A604 RH Rear parking brake cable
6 W500021 Parking brake cable-to-support plate bolt (2 required)
  1. Remove the brake disc shield. For additional information, refer to Brake Disc Shield in this section.
  1. Remove the 2 parking brake cable-to-support plate bolts, disconnect the parking brake cable from the lever and position the cable aside.
    • To install, tighten to 23 Nm (17 lb-ft).
  1. Remove the 2 dust boot shield bolts and the dust shield.
    • To install, tighten to 10 Nm (89 lb-in).
  1. Remove the dust boot.
Edited by WWWPerfA_ZN0W
