Advance Auto: Castrol Magnatec 0W20 5 qt $7.19
WWWPerfA_ZN0W
Typo? I don't know for sure. I am going to try picking up my order within the hour.
http://shop.advanceautoparts.com/p/castrol-cas-mag-0w20-5qt-06006/10838501-P
Hope you have success with it as well. I have attached data sheets for comparative purposes.
Castrol edge w Syntec PDS.pdf
Castrol Magnatec 0w20 PDS.pdf
0-20 is def not necessary, 5-20 is OEM, correct. I typically use 5-20, but if I can get 0-20 cheap, I see no harm in using it, esp if full synthetic. I won't put in 5w-30 though, unless the PDS matches very closely with or betters the Motorcraft 5-20 Syn Blend PDS. Even though the label on synthetics says the weightage, not all oils are same in their characteristics, weightage being the same.
