2008 Edge Limited AWD firing order?
SlickBlueEdge
Well I never....exposing your topless engine to the public....
Firewall side of engine (passengerside to driverside)
1,2,3
Radiator side of engine (passengerside to driverside)
4,5,6
So #4 would be the the leftmost cylinder of the 3 visible to you, right next to the oil fill cap.
112_0703_10z%2B2007_ford_edge_sel_plus_a
Swap the #4 coil with #5 or #6, see if the misfire moves with it. With any luck it may be just a coil. Could be a spark plug issue as well if they are original to your Edge. If the coil is not it, then pull the plugs and check the gaps.
Try Techron Concentrate or BG 44K, two of the top cleaners in the industry. Proceed straight to GO with these cleaners, don't bother with anything else.
  • 3 years later...
