Digital speedometer for 2010 Edge
With access to programming the IC, maybe some wiring/soldering work, I am sure it's possible. Unlikely to be a quick switch in/out though.
The cluster is a gateway module and distributes all the CAN messages out to other modules. What changed was the protocol of all the CAN messages. Basically the new cluster speaks a different language than the old one. No amount of programming is going to be able to fix that, you would have to create a custom "translator box" to put in between the new cluster and everything else.
