2012 Edge A/C "possessed"
jward
Hi. In the last week the A/C on my 2012 Ford Edge Limited has been acting strange. I have the Sync system and while driving down the road, my A/C with increase the fan speed with no one touching the buttons! And its not in AUTO mode to regulate the temp. So since its cooling down a bit, the A/C was off and again out of the blue with no one touching any buttons, the A/C popped on and increased the fan speed. I swear its possessed. Can there be a stuck mechanism behind the panel? Has anyone else had this weird problem and how was it fixed? Thanks for any info!
Do you also get the beep sound similar to when touching the controls? or maybe see the fan speed icon in the left bottom corner? This is just to confirm that it might be some grease or dirt causing the control panel to register touches. If that is the case, maybe a thorough cleaning will help. Another stop would be to take of the panel & try to clean it from behind (might need to disassemble it), last thing might be a defective panel. Others might have better ideas.
