JEHAN Posted November 8, 2017 Report Share Posted November 8, 2017 Hi, This is my first time here and would like some help locating where to install core heater for 2012 Ford edge 3.5 V6? Went under the vehicle and couldn't find where to plug it. went to Kat website where the heater is made and its saying RR side of the engine. If someone has photos that will be very helpful , Went to a Ford dealer and they where not able to install it Thank you Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted November 8, 2017 Report Share Posted November 8, 2017 I found this on the Web 2011-11-19_221938_11_edge_block_heater.pdf 1 Quote Link to comment Share on other sites More sharing options...
darkstar89 Posted May 11, 2025 Report Share Posted May 11, 2025 I know this is an old thread but I couldn't find much info on the topic. I was experiencing a small coolant leak occasionally. About 1/4 oz at most. I hunted all day for where it could be coming from. Turns out that it's coming from the block heater. I didn't even know it had one!!! Sure enough I found the plugin tucked into some wiring on top of the radiator fan. The location of the block heater is on the back of the block (near the firewall) directly above the oil pan drain plug. It's way up there and you can barely see it from underneath. I've attached 2 pictures showing it's location. Quote Link to comment Share on other sites More sharing options...
Haz Posted May 11, 2025 Report Share Posted May 11, 2025 Welcome to the Forum @darkstar89! Relevant sections from the 2013 Edge Workshop Manual, which should apply to 2007-2014 Edge 3.5L 3.7L block heater installations, are attached below as PDF documents... Good luck! Link to this FordParts webpage Block Heater — 3.5L, 3.7L - Removal and Installation - 2007-2014 Edge Workshop Manual.pdf Cooling System Draining, Filling and Bleeding — 2.0L, 3.5L, 3.7L - General Procedures - 2007-2014 Edge Workshop Manual.pdf Catalytic Converter — RH - Removal and Installation - 2007-2014 Edge Workshop Manual.pdf Heated Oxygen Sensor (HO2S) and Catalyst Monitor Sensor (CMS) — Exploded View, 3.5L and 3.7L - Removal and Installation - 2007-2014 Edge Workshop Manual.pdf Exhaust Y-Pipe - Removal and Installation - 2007-2014 Edge Workshop Manual.pdf Transaxle Support Insulator — Anti-Roll - AWD Only - Removal and Installation - 2007-2014 Edge Workshop Manual.pdf 1 Quote Link to comment Share on other sites More sharing options...
