Platinum White Posted November 30, 2017 Report Share Posted November 30, 2017 The owners manual gives instructions for adjusting the vertical aim, but no mention of the horizontal aim. My right light illuminates the right shoulder leaving the center of the road darker. I'm not too much interested in seeing whats in the ditch. How can I adjust the horizontal aim? Quote Link to comment Share on other sites More sharing options...
omar302 Posted November 30, 2017 Report Share Posted November 30, 2017 As far as I know, Ford vehicles for a long time do not have horizontal adjustment. Let your dealer check it out. 1 Quote Link to comment Share on other sites More sharing options...
omar302 Posted March 27, 2018 Report Share Posted March 27, 2018 Old thread, but just in case the issue was not resolved for you, I have 2 suggestions: 1- Check that the bulb is correctly seated. 2- Loosen the bolts holding the headlight on the top & try to tilt the headlight a bit to the direction you want, especially from the bolt on the grille side. The holes for the bolts allow slight movement so it might give you a little horizontal adjustment. 2 Quote Link to comment Share on other sites More sharing options...
