bronconut Posted February 4, 2018 Report Share Posted February 4, 2018 ok i am sure this has been covers thousands of time....i have seen the TSB for replacing the coil pack etc....for up to 8 years and 80K i have a 2008 Edge limited AWD with 115K .... left work on friday and it started to skip, then throw a check engine light. waiting on the wife to pick me up, scoweed the interwebs and forum to see what it might be. Got it on a trailer and on the way home stopped by my local parts store for them to read the codes. had P0353, P0355, P0356 misfire codes. i figured crap blow three COP's as that seems to be a commonish thing. Did not know if the plugs had ever been done and decided to just replace all the plugs and coils since they had to come out anyway. did pull the battery loose while doing the work... After changing all the plugs and coils.... it is still skipping and has a check engine light again. Have not hit it with a code reader but based on what i am reading, am I looking at a dorked up PCM?? thanks -Shane Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted February 5, 2018 Report Share Posted February 5, 2018 Sadly, I think so. You can test the PCM coil drivers, see if beyond specifications. That is the best/easiest way to tell. Sometimes it is a fuel injector at fault, but save that thought for another day. 2007 Edge Integrated Ignition Coil On Plug Coil A Through J Failure.pdf Quote Link to comment Share on other sites More sharing options...
bronconut Posted February 5, 2018 Author Report Share Posted February 5, 2018 Sadly, I think so. You can test the PCM coil drivers, see if beyond specifications. That is the best/easiest way to tell. Sometimes it is a fuel injector at fault, but save that thought for another day. thanks, i do have access to a testing tool of this caliber so i guess i am off to do that and then try and find a respectable / reasonableplace to order a pre-programmed unit. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted February 5, 2018 Report Share Posted February 5, 2018 if it does turn out to be the PCM, i recommend getting it fixed by circuitboardmedics.com , a very reputable shop. 1 Quote Link to comment Share on other sites More sharing options...
macbwt Posted February 8, 2018 Report Share Posted February 8, 2018 Ditto on the toasted PCM 1 Quote Link to comment Share on other sites More sharing options...
