Installing rca line output converter 2014 edge limited
I have a 2014 edge limited. I use to have a sel and had no problems hooking it up. But with the limited Im stumped. I went through the wires behind the head unit but cant figure out what wires are for the back door speakers. Also this has the Sony nav system in it. And the wires behind it are different then the sel I use to have. Any help would be appreciated
Thanks for the info. I have what color wire is what but I have the limited version. With nav system and Sony sound when I look at wires behind them there is no brown/ yellow green/white for left rear speaker and brown/blue and brown/white for right rear. So Im stumped on this one. Im tempted to open up the mass bundle of wires on driver floor and look for the wires in there cus they dont match up behind the dash
Anyone feel free to correct me, I apologize in advance if the following is misinformation. Have you considered pulling the rear speaker and identifying the speaker wires that way? Once you see the colors/ wires you are looking for you can access them by removing the passenger side door pillar trim.
I believe you can access both sets of rear speakers there. I may be mistaken hence the apologies in advance.
Good Luck, and Happy Hunting!
Edited by onyxbfly
Yep I know the colors for both rear speakers. I rather not have to run wires from my right pass to the left where my amp is located but if I have to thats my only option at the moment. Either run it all the way around or under the carpet is the best option. Hate to take it somewhere for them to do it
