Zemzabob Report post Posted March 13, 2019 My 2013 Ford Edge Soort started overheating when stopped, I noticed that the fans were not working at all even with the ac on. Knowing that the fans going out is a common problem I replaced the whole fan assembly, but the fans still do not work. I also changed the 60 amp fuse with no luck. Not sure what to try next any help would be greatly appreciated. I’ve noticed others that have had the same issue, but have not seen them solve it. I have searched the forum for answers with no luck. Share this post Link to post Share on other sites
omar302 Report post Posted March 13, 2019 OEM replacement fan? There have a lot issues with people when using aftermarket fans on the Edge. 1 Share this post Link to post Share on other sites
JJHenson Report post Posted August 21, 2019 I’m having the same issue. Ordered my fan assembly from a Ford dealership as well. Changes the 60 amp fuse (no tow package) & the hoses are warm. Also there’s no leaks & the coolant is full. Help! Share this post Link to post Share on other sites
