bicsintegra Posted June 30, 2019 Report Share Posted June 30, 2019 my wife's 2013 edge sport only blows cold air on the passenger side, the driver side is hot like the heat is on. it has the dual climate zone controls, has anyone else had this issue? Quote Link to comment Share on other sites More sharing options...
omar302 Posted June 30, 2019 Report Share Posted June 30, 2019 It is most likely the blend door actuator. 1 Quote Link to comment Share on other sites More sharing options...
pc2013edge Posted July 13, 2019 Report Share Posted July 13, 2019 Yes, it's happened to me twice on my 2013 Edge Limited - except it was the opposite - I had AC on the drivers side and heat on the passenger side of the centre vents. Good news - there's an easy fix that I found when I googled the issue - and I used it both times and it fixed it both times - best part is that the fix costs nothing. With the car in park, press the POWER and DEFROST buttons at the same time on the main console. Hold them down for about 3-5 seconds. Then press POWER again and see if the cool air flows on both sides of the vent. Let me know if it works. Saved me a trip to the dealership both times and cost me zero to fix. #winning Quote Link to comment Share on other sites More sharing options...
Sanoa Posted September 8, 2019 Report Share Posted September 8, 2019 On 7/13/2019 at 4:16 PM, pc2013edge said: Yes, it's happened to me twice on my 2013 Edge Limited - except it was the opposite - I had AC on the drivers side and heat on the passenger side of the centre vents. Good news - there's an easy fix that I found when I googled the issue - and I used it both times and it fixed it both times - best part is that the fix costs nothing. With the car in park, press the POWER and DEFROST buttons at the same time on the main console. Hold them down for about 3-5 seconds. Then press POWER again and see if the cool air flows on both sides of the vent. Let me know if it works. Saved me a trip to the dealership both times and cost me zero to fix. #winning What was the point of doing this? What role did it play in getting the AC to work as needed? Quote Link to comment Share on other sites More sharing options...
ghost0217 Posted December 27, 2020 Report Share Posted December 27, 2020 I know this question was asked over a year ago, but for the sake of possibly helping someone else out in the future, the procedure that was mentioned about holding the defrost/power button for 5 seconds and then pressing the power button is some sort of AC reset/recalibration. When you do that, you will hear the small motors (blend door actuators) reset and run through a full sweep. It will then move the air across all vents in order and once done, it usually re-aligns the blend door actuator in question. This is a temp fix though. It will get you through that one issue, but will come back. Eventually you will want to replace the affected actuator. The passenger side one is behind the glove box, the driver side one is up under the dash/center stack. Each part is roughly $50 if applicable. 1 Quote Link to comment Share on other sites More sharing options...
