12v plugs
Plug in a 12v LED (or other low draw accessory) and check it out!  If the port doesn't shut off immediately set a timer and check it out every 15 minutes or so.
If your Gen1.5 works like Gen2 models the power ports can be set (using FORScan) in increments ranging from on/off with engine start stop to always on.  A battery protection system will shut the ports down if voltage falls to a level that could threaten engine start.  The OEM setting was something like an hour and a half.
