Cyberdave Posted October 11, 2019 Report Share Posted October 11, 2019 (edited) This is the weirdest thing. 2013 Edge SEL. The brake booster was replaced (under warranty) along with the master cylinder about 6 weeks ago by a local Ford dealer. Last week I parked in my driveway which is on a slight incline and when pressing the remote to lock the car the rear brake lights stayed on. (I am NOT using the emergency brake. ) I tried using the remote to unlock and relock the car and it didn't work. I got in the car and turned it on and off and that didn't work and finally what worked was turning the car on, putting it in drive, putting it back in park, then turning it off. Then get out and lock with the remote and the brake lights turned off. This happens when the car is parked either front in or backed in. It does not happen when the car is just on the street or in a parking lot on level ground. It is the weirdest damn thing! Does anyone have any idea why this is happening? Could it be related to the brake work that was done? Or something else? I haven't taken it in yet but I'm going to have to. ... Thanks! Edited October 11, 2019 by Cyberdave Quote Link to comment Share on other sites More sharing options...
omar302 Posted October 11, 2019 Report Share Posted October 11, 2019 It is weird. Are you sure it is the brake lights? That would also include the 3rd light in spoiler. Also, if I'm understanding you correctly, it only happens when parked on an incline but not when parked on a level ground? If yes then I'd also suspect the brake work, maybe the brake light switch is too sensitive that the inclination is causing it to engage. Or maybe it a defective switch. Does cruise control work fine? If the brake lights are randomly turning on on bumps cruise control should disengage. Quote Link to comment Share on other sites More sharing options...
Cyberdave Posted October 11, 2019 Author Report Share Posted October 11, 2019 5 hours ago, omar302 said: It is weird. Are you sure it is the brake lights? That would also include the 3rd light in spoiler. Also, if I'm understanding you correctly, it only happens when parked on an incline but not when parked on a level ground? If yes then I'd also suspect the brake work, maybe the brake light switch is too sensitive that the inclination is causing it to engage. Or maybe it a defective switch. Does cruise control work fine? If the brake lights are randomly turning on on bumps cruise control should disengage. Yes rear brake lights with spoiler light. Yes only on inclines (other ones I've parked on too) and not on level ground. I dont use cruise control but I could try it. With more testing I found that when I turn the car back on, I just need to press the brake pedal and not put it in gear, then turn it off, in order for pressing the remote to get the car to lock with no brake light on. Quote Link to comment Share on other sites More sharing options...
Cyberdave Posted October 22, 2019 Author Report Share Posted October 22, 2019 (edited) I took the car into Ford and they looked into it. They said that the brake light switch was sticking (which is why pressing the brake pedal again would turn the lights back off) and they were able to reproduce the problem even on level ground. They claimed it was not related to the booster/master cylinder work. They replaced it - $30 for the part and $135 for labor. Edited October 23, 2019 by Cyberdave 1 Quote Link to comment Share on other sites More sharing options...
PaulSchott Posted October 23, 2019 Report Share Posted October 23, 2019 Sounds like they damaged it when they installed the booster or it was just out of adjustment. What a coincidence LOL 1 Quote Link to comment Share on other sites More sharing options...
mvan231 Posted November 12, 2019 Report Share Posted November 12, 2019 On 10/22/2019 at 12:57 PM, Cyberdave said: I took the car into Ford and they looked into it. They said that the brake light switch was sticking (which is why pressing the brake pedal again would turn the lights back off) and they were able to reproduce the problem even on level ground. They claimed it was not related to the booster/master cylinder work. They replaced it - $30 for the part and $135 for labor. That was going o be my suggestion as well Quote Link to comment Share on other sites More sharing options...
