Weird electrical problem on a 2007 Ford Edge 3.5l Dash all over the place.
DragemD
Last week the battery light came on. I took it in and they figured it was the alternator. Fine I paid, they installed a new one, and on the way home the battery light came on, then it went off a minute later than the came back a few minutes later than the advance track glitched (beeped), then the ABS brake light came on, and when I turn off the car the Throttle Control/Powertrain warning light blinks and stays blinking. WTF!!!
Of course, I took it back, and it's been in the shop for 4 days. I called and he said he tested at the alternator and it was putting out about 14v but at the battery, it sometimes drops to about 8v. They swapped the battery with a good one and the same issue. It happens completely at random, it might run fine for 10 minutes then goes out. As for as running goes it sounds fine but it's not charging enough when it glitches. I figured they got a bad alternator but again they have had it for 4 days and no updates.
I can fix mechanical but electrical is out of my wheelhouse.
Very odd that they test the alternator and charger but not check the wiring and the terminals.  If the voltage is confirmed 14.4+ at the alternator, then the problem has to be in excessive resistance somewhere in the circuit. This is basic diagnostics and they should be able to perform them.
You can look up videos for yourself on YT.  Plenty of reputable channels that put out helpful information.  "Voltage Drop" is the search term I normally use.
There have been many reports of replacement alternators being bad right out of the box, so that's a good possibility.   The question is when it drops to 8V at the battery is it still 14.4V at the alternator or does it also drop to 8V?   If it's 14.4V at the alternator but 8V at the battery then it's a wiring/connection issue.   Also don't rule out a bad replacement battery - make sure they test the CCAs on it not just voltage.
Also be aware the alternator may be variable output so it may not always put out 14.4V - could be less (controlled by the PCM).  But I don't know if it goes as low as 8V and under normal operation it certainly wouldn't cause the check light.
