NonnieMiss Posted February 15, 2021 Report Share Posted February 15, 2021 Hi. I’m new and hope I’ve found the right forum for my question. I have a 2016 Edge Titanium. Love it to pieces, never really had any issues. Since lockdowns, I’m not driving as frequently but noticed the last few times I’ve driven, my interior chimes sound different. They used to have kind of a softer stereo sound, but now it sounds abrasive and very treble like and like it’s coming only from the left speaker by the windshield on the drivers side. Once this resolved itself when I got back in the car, but this time around it hasn’t. does anyone know what this is or how I can fix it? I realize it’s such a petty thing but for some reason it irritates me. ? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted February 15, 2021 Report Share Posted February 15, 2021 My initial thought is your vehicle battery is weak (especially since you are not driving very often). I'd have it load tested (or test its CCA reserve). Normally, most shops tests only voltage which is NOT a good indicator of a battery's internal health. Being retired, I also don't drive as much as I used to. This is the battery tester I use to test both our car's batteries. It tests both the CCA capacity rating, as well as the cars entire charging system. (Also good for testing the tractor and generator battery's too). https://www.amazon.com/dp/B00IZFNJ6Y/ref=cm_sw_r_cp_apa_fabc_5927DG7C5V633JGECH40?_encoding=UTF8&psc=1 1 Quote Link to comment Share on other sites More sharing options...
NonnieMiss Posted February 16, 2021 Author Report Share Posted February 16, 2021 Thanks!! Quote Link to comment Share on other sites More sharing options...
jmr061 Posted February 16, 2021 Report Share Posted February 16, 2021 The chimes go through the stereo system typically if everything is good and healthy and the can bus network is all timed and in sync. If anything is amiss it defaults to the instrument cluster speaker. That is what is happening. Probably because of the weaker battery voltage from sitting. 3 Quote Link to comment Share on other sites More sharing options...
NonnieMiss Posted February 16, 2021 Author Report Share Posted February 16, 2021 37 minutes ago, jmr061 said: The chimes go through the stereo system typically if everything is good and healthy and the can bus network is all timed and in sync. If anything is amiss it defaults to the instrument cluster speaker. That is what is happening. Probably because of the weaker battery voltage from sitting. You gave a much better description of my problem, thanks. ? I have ordered the battery thing and will proceed as necessary. Appreciate the help! Quote Link to comment Share on other sites More sharing options...
DaMiFo Posted February 17, 2021 Report Share Posted February 17, 2021 (edited) If you are not driving much, it is completely normal for this generation Edge and Fusion. Either (as posted above) the battery could be going bad due to age, OR after a while the car will enter a "deep sleep" where all modules stop checking-in with eachother to save power. The next time the car is driven for a little while things will adjust and you'll get the full chime again (as you experienced once). If it hasn't gone away right away, your battery may need to charge if the car has been sitting for a while, or (again as posted above) your battery may be on it's way out. Try going for a longer drive to charge up the battery a little more. If you haven't yet experienced it, your backup warning beeps will also come from the instrument cluster rather than the rear speakers too. Edited February 17, 2021 by DaMiFo Quote Link to comment Share on other sites More sharing options...
OasisUK Posted June 17, 2021 Report Share Posted June 17, 2021 Thanks for this great info. This has happened to me as well recently and didn't know what the heck was going on. Car is barely getting driven lately so i guess there is my answer. Appreciate it! Quote Link to comment Share on other sites More sharing options...
