cornelljl Posted July 27, 2022 Report Share Posted July 27, 2022 I have a 07 Edge and the AC on MAX AC or on HIGH blows the same as a limp fan on low. The left side def blows less then the right, however the whole system feels like it is on low when it is on high. All of the 4 options blow diff, so the switch does work. Being old and the parts not being high, I replaced the blower motor and no change, I DID NOT change the resistor though. It is 113 degrees so I am not aimlessly searching lol. Any thoughts or has anyone else had this problem? Quote Link to comment Share on other sites More sharing options...
omar302 Posted July 27, 2022 Report Share Posted July 27, 2022 Did you check the cabin air filter/screen? 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted September 6, 2022 Report Share Posted September 6, 2022 Ever get a fix for this? If manual a/c, probably the resistor pack or switch. DATC Module if automatic system. Quote Link to comment Share on other sites More sharing options...
