dabangsta Posted December 21, 2022 Report Share Posted December 21, 2022 Once we signed all the papers on the 2019 Edge SEL, they detailed it one more time. Somehow they got that slick nasty spray on the back side of the cluster. I didn't notice it until the sun hit it, but I would have noticed it on the test drive. Can the back of the clear plastic lens be accessed non destructively and easily? It doesn't seem to be going away, it isn't going to evaporate it doesn't look like. Quote Link to comment Share on other sites More sharing options...
Haz Posted December 21, 2022 Report Share Posted December 21, 2022 (edited) Surprisingly inexpensive, from Ford's online parts site... Low Series Analog Cluster page link Sport Instrumentation Cluster page link Document download link> Instrument Panel Cluster - Removal and Installation - 2019 Edge Workshop Manual.pdf VIN-specific part numbers for Engineering/originally installed and Service/replacement... Good luck! Edited December 21, 2022 by Haz 2 Quote Link to comment Share on other sites More sharing options...
dabangsta Posted December 21, 2022 Author Report Share Posted December 21, 2022 Thanks, that attached workshop manual pdf is very handy! Lens appears to very easy to separate. With the 201a group I have the bottom cluster with the 2 screens. 1 Quote Link to comment Share on other sites More sharing options...
bofus Posted December 21, 2022 Report Share Posted December 21, 2022 I had "factory splatter" on one of my cars back in the day. I had to remove the entire cluster and separate the front plastic from the rest to get at it. I think the person putting the cluster together at the factory must have sneezed on it as it was sideways. No way could have it been done when in place. Yep...super annoying to look at. You can see the diagonal "drops" of something on the tach in the dark area. Cleaned up easily, just a pain to get to it. 1 Quote Link to comment Share on other sites More sharing options...
Nbanic5577 Posted January 28, 2023 Report Share Posted January 28, 2023 Needing to do a similar project to my Edge. Replacing just the lens cover. Anyone know if i will have to actually unplug and remove the whole cluster or can it just be done without removing it? Quote Link to comment Share on other sites More sharing options...
Tony4Edge Posted January 26, 2025 Report Share Posted January 26, 2025 Nbanic5577 - I presume you probably got it done last year - but you don't have to, but it would make it easier. I was able to balance it while I changed the mask without disconnecting it. The guide was very useful taking the dash apart. The whole process took about 45 minutes moving slow and steady. 1 Quote Link to comment Share on other sites More sharing options...
