What to expect after 100,000+ miles
I read "what to expect after 200,000 miles+" and I'm a long way away from that but what about after 100,000 miles.
Its my wifes car and its been a great car! which has me wondering (since everything breaks at some point) whats going to break first and will it leave her stranded?
I say 1st. because other than tires, brakes and wipers, oil changes nothing has broke! Happy to say "What a car" Great job FORD!
Speaking from 130k+ miles.
New PTU, replaced brake booster, 1-tie rod end, windshield washer spray nozzles, 1-vacuum hose, power seat back lumbar assemblies (both drivers and passengers), new TPMS units (one failed, replaced all four), new valve core on spare tire (rotted ftom age), replaced Chrome wheel (hit a curb), new battery 3x, drivers door handle, new accordion sealing strip on drivers side (seals BAMR sliding glass, old seal softened in hot sun, twisted when closed and became fixted in twisted position). New shocks on rear.
Recalls; gas tank (was rusted on top), air bags.
All prior to 130k, nothing since (so far).
All maintenance done at Lincoln (Ford)  garage, Motorcraft parts (100%).
Routine maintenance done per Lincoln  Maintenance Manual (plugs, filters (oil, air, cabin & seat), all fluids changed, plugs at 90k, wiper blades, headlight bulbs. Coolant change over from gold to current.
Water pump still good, struts good, transmission & engine good. All systems nominal.
No leaks engine or transmission or rear differential.
One minor rust spot on roof black strip next to BAMR (hit by flying rock).
If this helps, I've kept a log of maintenance done on my 2011 Limited. First few entries are previous owner off the Carfax,  I've owned it since 40K miles and any 2016 entries (like the PTU failure) and have  attempted to maintain 5K mile oil changes and tire rotations:
Date  Mileage  Service
11/19/11            6,695 Oil & Filter Change
06/09/12            9,375 Oil & Filter Change
04/06/13          16,279 Oil & Filter Change
04/06/13          16,279 Replace Cabin Air Filter
03/20/15          35,377 Oil & Filter Change
03/20/15          35,377 Replace wipers WW2601PF/WW2001PF/WW1412
09/24/15          36,685 Oil & Filter Change
09/24/15          36,685 Front & Rear Brakes Replaced
11/24/15          40,753 Oil & Filter Change
11/24/15          40,753 Replace wipers WW2601PF/WW2001PF/WW1412
11/24/15          40,753 Replace Air Filter FA1884 FP65
01/04/16          40,168 State Insp
04/26/16          43,909 State Insp
06/14/16          47,515 Replace PS Lines - warranty
06/14/16          47,515 Replace PTU - Warranty
06/14/16          47,515 Oil Change/Rotate Tires
11/09/16          55,137 State Insp
11/09/16          55,138 Oil Change/Rotate Tires
11/09/16          55,139 Transmission Flush
04/05/17          62,438 Oil Change/Rotate Tires
04/05/17          62,438 State Insp
08/18/17          70,643 Oil Change/Rotate Tires
11/18/17          76,197 Replace tires Michelin Lattitude 245/60/18 (4) + Mounting
03/23/18          80,761 Oil Change/Rotate Tires
06/21/18          85,064 Oil Change/Rotate Tires
07/02/18          85,354 Michelin blown tire replacement
08/18/18          88,000 Replace Front Rotors & Pads
09/14/18          90,000 Replace Rear Wiper Housing
12/21/18          96,092 Oil Change/Rotate Tires
04/11/19       102,390 State Insp
04/11/19       102,390 Oil Change/Rotate Tires
06/19/19       104,668 Opitimum Battery
10/23/19       109,759 Oil Change/Rotate Tires
01/24/20       114,752 Oil Change/Rotate Tires
01/25/20       114,752 Replace Rear Rotors & Pads
04/11/20       118,278 Oil Change/Rotate Tires
04/11/20       118,278 Outer Tie Rod Ends
04/11/20       118,278 4 Wheel Alignment
04/11/20       118,278 State Insp
12/15/20       124,525 Oil Change/Rotate Tires
08/28/21       141,888 Front Duralast Brake Pads DG1258
08/30/21       142,034 Oil Change/Rotate Tires
08/30/21       142,054 Replace tires Michelin Lattitude 245/60/18 (4) + Mounting
08/31/21       142,054 Air Filter
08/31/21       142,055 Battery replaced under warranty
02/14/22       152,067 Cylinder 1-3-5 Coil pack (EBC1013) & plugs (XP5363)
02/14/22       152,067 CV axle left (tone ring broken)
02/18/22       152,300 Replace Exhaust
02/19/22       152,306 Oil Change/Rotate Tires
05/06/22       158,734 Oil Change/Rotate Tires
05/06/22       158,734 Alignment
09/10/22       162,000 Replace right rear brake caliper and pads
11/03/22       165,700 Oil Change/Rotate Tires
11/17/22       167,000 Replace Backup Camera
Rereading enigma-2's  always helpful posts,  I see my maintenance log and my Parts log aren't the same.  The maintenance log missed several DIY part installations, so to include it all, here's the $1,762 I spent in parts over the years....
01/24/16 41,000 SPORT GRILLE INSERTS - PRIMED Black
07/02/17 76,197 Mustang GT Wheels Craigslist
07/03/17 76,197 Replace Nav Display Panel - hazards turning on unattended
06/21/18 88,000 Wagner Ceramic Front Pads set - Amazon
08/18/18 88,000 Front Rotors - Advance Auto YH147502P
09/14/18 90,000 Rear Wiper Housing - 9T4Z-17526F
06/19/19 104,668 Optimum Battery - Best Ford
01/25/20 114,752 Wagner Rear Pads - Amazon
01/25/20 114,752 Wagner Rear Rotors - Amazon
04/11/20 118,278 Duralast Outer Tie Rod Ends - Autozone
04/23/20 119,000 Bosch Icon 18in Beam Wiper Blade
04/23/20 119,000 Bosch Icon 20in Beam Wiper Blade
08/28/21 141,888 Duralast Brake pads - Autozone DG1258/DG1377
08/31/21 142,054 FRAM Extra Guard Air Filter, CA10242
12/13/21 148,800 Steering Angle Sensor
02/10/22 151,877 Philips 42302C1 D3S Standard Xenon HID Headlight
02/15/22 151,877 Carquest Premium Ignition Coil
09/10/22 162,000 Rear Calipers - Chuck & Eddie's
11/16/22 167,000 Rear View Park Assist Back Up Camera
