Haz Posted May 14 Report Share Posted May 14 (edited) Additional information on Inline Connector C1026 (described as "in engine compartment on left side") attached below as PDF documents... Good luck! Inline Connector C1026 - Location - 2019 Edge.pdf Inline Connector C1026 - Pinout Diagram with Fuller Circuit Description - 2019 Edge.pdf Inline Connector C1026 - Pinout Diagram - 2019 Edge.pdf Inline Connector C1026 - Location - ENHANCED IMAGE - 2019 Edge.pdf Edited May 14 by Haz 2 Quote Link to comment Share on other sites More sharing options...
johnmarkp Posted May 21 Author Report Share Posted May 21 (edited) I got the VDM and the connectors. I ran power and CAN2 (from the headlight control module) to the unit. The car does not see the VDM according to forescan. The VDM is powered up, I got 5v on the height sensor reference voltage pin. I reversed the CAN2 wires just to make sure. The wiring diagrams have the + and - switched sometimes. I put a cheap scope on the CAN2 wires and it looks like I have the right ones. I think there may be a setting in a module somewhere that tells the car that VDM is part of the allowed configuration. I tried changing the setting in the IPC that turns on the display part and it would not write. It gave a module configuration error. Not sure what to do next. I only found one reference to "Continuously Variable Suspension" on all the usual forescan type sites. It is for the IPC part. Edited May 22 by johnmarkp 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted May 22 Report Share Posted May 22 Did you create a new FORScan profile? Quote Link to comment Share on other sites More sharing options...
johnmarkp Posted May 22 Author Report Share Posted May 22 I did create the new profile. I am going to try a different place to grab the CAN2 signal and make sure the signal is actually getting into the VDM 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted June 4 Report Share Posted June 4 On 5/21/2025 at 4:41 PM, johnmarkp said: The car does not see the VDM according to forescan. Did you get it to show up? FORScan only shows the modules that are physically present and that it has the information for by vehicle model and profile. Quote Link to comment Share on other sites More sharing options...
johnmarkp Posted June 5 Author Report Share Posted June 5 I did not get it to show up. I confirmed that it was powered up and I am 99% sure that the CAN2 was hooked up properly as well. I assume that the profile characteristics are in as built database. I cannot figure out how to fool the system. It would be interesting to compare my 2019 ST with a 2019 Nautilus with and without Adaptive suspension. Can we still get the as built data by VIN number? I don't remember how to view the as built data, can someone remind me? 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted June 5 Report Share Posted June 5 30 minutes ago, johnmarkp said: Can we still get the as built data by VIN number? I don't remember how to view the as built data, can someone remind me? Yes. Go to https://www.motorcraftservice.com/AsBuilt/. Enter the VIN number and complete the security check. Use AsBuilt Explorer by Compulsive Code to compare. 2019 Nautilus: 2LMPJ6J93KBL35167 Black Label: 2LMPJ9JP7KBL47905 1 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted June 5 Report Share Posted June 5 FORScan may not show the VDM because it is not expecting to see it for your vehicle. However, if you had a Nautilus profile, it might show up. 1 Quote Link to comment Share on other sites More sharing options...
johnmarkp Posted June 5 Author Report Share Posted June 5 Thanks. Lots of differences. I will have plenty to do on rainy days.😊 1 Quote Link to comment Share on other sites More sharing options...
dolsen Posted June 6 Report Share Posted June 6 I added an HCM to a 22 F150 and there was some programming that had to be done to it before I was able to program it. I believe it needs to be initialized to the vehicle. Don't ask me how to do that though because I didn't do it😅 1 Quote Link to comment Share on other sites More sharing options...
Haz Posted June 6 Report Share Posted June 6 On 4/16/2025 at 2:17 PM, johnmarkp said: HAZ, do you have access to the wiring diagram that will give me the part number for the female connector? Is is C4044, left rear damper solenoid. @johnmarkp: Just noticed this and I don't believe I fulfilled it -- attached below as PDF document(s)... Good luck! Vehicle Dynamics Control Module (VDM) - Wiring Diagram - 2023 Nautilus.pdf REAR SHOCK ABSORBER SOLENOID VALVE LH - Connector C4044 Pinout Details - 2023 Nautilus.pdf 2 Quote Link to comment Share on other sites More sharing options...
johnmarkp Posted Friday at 04:28 PM Author Report Share Posted Friday at 04:28 PM Does anyone have any idea how to do the initialize to vehicle thing? Or any other work around for that matter. I am stuck on this project. 1 Quote Link to comment Share on other sites More sharing options...
