OmahaBob Posted August 8, 2024 Report Share Posted August 8, 2024 Has anyone tried to retrofit the 2021-2024 Bronco 2.7 OEM M-6766-B27 Engine Air Oil Separators LH & RH into a Edge ST? I would prefer to use ford products to protect my warranty. Many have checked with their dealer and the dealer said catch cans would void the warranty. Thanks Quote Link to comment Share on other sites More sharing options...
1004ron Posted August 8, 2024 Report Share Posted August 8, 2024 3 hours ago, OmahaBob said: Has anyone tried to retrofit the 2021-2024 Bronco 2.7 OEM M-6766-B27 Engine Air Oil Separators LH & RH into a Edge ST? I would prefer to use ford products to protect my warranty. Many have checked with their dealer and the dealer said catch cans would void the warranty. Thanks It's not my observation that "many" have said the catch can will void warranty - the law is not on their side when it comes to proving the catch can caused whatever engine failure. Quote Link to comment Share on other sites More sharing options...
TourGuide Posted August 10, 2024 Report Share Posted August 10, 2024 On 8/8/2024 at 4:29 PM, 1004ron said: It's not my observation that "many" have said the catch can will void warranty - the law is not on their side when it comes to proving the catch can caused whatever engine failure. https://duckduckgo.com/?t=h_&hps=1&start=1&q=magnuson-moss+act&ia=web Quote Link to comment Share on other sites More sharing options...
Cerberus Posted August 10, 2024 Report Share Posted August 10, 2024 3 minutes ago, TourGuide said: https://duckduckgo.com/?t=h_&hps=1&start=1&q=magnuson-moss+act&ia=web that act only applies to who services the vehicle (maintenance or repairs) and invalidation of factory (manufacturer's) warranty. does not apply to modifications or 3rd party warranties. Quote Link to comment Share on other sites More sharing options...
Cerberus Posted August 10, 2024 Report Share Posted August 10, 2024 On 8/8/2024 at 4:29 PM, 1004ron said: It's not my observation that "many" have said the catch can will void warranty - the law is not on their side when it comes to proving the catch can caused whatever engine failure. you may be right, but i would not want to have to battle it out in court with either a dealership or the manufacturer, whether or not the modification caused engine failure. I mean, i know a catch can won't cause an engine failure, but lawyers are expensive as heck.. Quote Link to comment Share on other sites More sharing options...
1004ron Posted August 10, 2024 Report Share Posted August 10, 2024 Agreed, legal battles aren't welcome regardless how strong your case may be, so if there's any uncertainty you could use the type of catch-can that I have which takes a couple of minutes to remove/install as and when needed. Definitely wouldn't run my 2.7L V6 without it. 1 Quote Link to comment Share on other sites More sharing options...
Cerberus Posted August 10, 2024 Report Share Posted August 10, 2024 1 minute ago, 1004ron said: Agreed, legal battles aren't welcome regardless how strong your case may be, so if there's any uncertainty you could use the type of catch-can that I have which takes a couple of minutes to remove/install as and when needed. Definitely wouldn't run my 2.7L V6 without it. agreed on all! Quote Link to comment Share on other sites More sharing options...
OmahaBob Posted August 11, 2024 Author Report Share Posted August 11, 2024 On 8/8/2024 at 3:29 PM, 1004ron said: It's not my observation that "many" have said the catch can will void warranty - the law is not on their side when it comes to proving the catch can caused whatever engine failure. My bad. "Many" = 3 (saw 2 or 3 youtube videos) after I bought the JLT 3.0. Thanks Quote Link to comment Share on other sites More sharing options...
2021EdgeST Posted May 24 Report Share Posted May 24 No they don’t void warranty, I have run the JLT on several vehicles and they do work, got one on my ST currently helps a lot on long trips for sure, you see the oil that bypasses and would be deposited on the back sides of the intake valves and baked on Quote Link to comment Share on other sites More sharing options...
