Haz Posted September 19, 2024 Report Share Posted September 19, 2024 (edited) Edited December 7, 2024 by Haz 2 Quote Link to comment Share on other sites More sharing options...
Rumblesis Posted November 16, 2024 Report Share Posted November 16, 2024 Has anyone had this done yet? Will it adversely affect my Edge? Quote Link to comment Share on other sites More sharing options...
Ar Gerrit Posted November 19, 2024 Report Share Posted November 19, 2024 I also received the notice for our 2018 Edge. I'm very reluctant to get this done without further details. What emissions are potentially not met in real conditions? What does this reprogramming cause? I'm all for reducing actual emissions, but I'm concerned it will just decrease MPG or decrease performance by tuning the emissions for some theoretical compliance. It is just that Ford has done things like this in the past where they issued recalls that were 'easy for them' but not in the benefit of the owner. (E.g. this recent one 24-2188 Ford Wheel Technical Service Bulletin where instead of replacing a vacuum line to fix the partial engagement of 4A, they just cap them which disables 2H mode and always runs in 4A.) 1 Quote Link to comment Share on other sites More sharing options...
jumpsteady Posted November 20, 2024 Report Share Posted November 20, 2024 I got this notice as well for my 2015 Edge. It just so happens that the check engine light has periodically come on and off and am getting codes P2196 and P2198. Could this be a new Mass Air Flow Sensor or a new vapor canister purge valve is needed? Or could reprogramming the power control module possible fix this check engine light coming on? Any thoughts on this? Quote Link to comment Share on other sites More sharing options...
Cobra4fun Posted December 2, 2024 Report Share Posted December 2, 2024 On 11/20/2024 at 10:44 AM, jumpsteady said: I got this notice as well for my 2015 Edge. It just so happens that the check engine light has periodically come on and off and am getting codes P2196 and P2198. Could this be a new Mass Air Flow Sensor or a new vapor canister purge valve is needed? Or could reprogramming the power control module possible fix this check engine light coming on? Any thoughts on this? Doubt this recall would affect that Mass Air Flow Sensor code, but who knows. A P0420 or a P0430 Catalyst Efficiency code for a bad Catalytic Converter i think would be a likely result of this lack of proper programming since it affects tailpipe emissions. Quote Link to comment Share on other sites More sharing options...
ScooterBOSS Posted January 10, 2025 Report Share Posted January 10, 2025 Well I received this recall notice for my 2016 Ford Edge Titanium with the 3.5L standard (non-turbocharged) engine. So, when I went in to the local Ford dealership on 12/6/24 for an oil change I asked them to address this Recall Notice 24E10 that I received. They did it and I left but then over the next few days I noticed my average fuel economy started to drop. I have owned this Edge for 5 years and it has about 87,000 miles on it now and it has never dropped below 22.5 Avg MPG on the dash readout. In fact I always wondered if it was stuck at 22.5 so I would reset it and it would slowly settle back down to 22.5 but might do a little better on long trips but never dropped below 22.5. Now after the recall "FIX" it slowly over a few days dropped down to about 21.2 MPG which I'm not please with Ford about this. This reduction may not seem like much but I would think that a recall to reduce tailpipe emissions would not reduce fuel economy but instead possibly improve combustion and fuel economy! I called both local dealers and they really couldn't help me as they said this was a Ford Mandated Recall. When I called the Recall customer service phone number I got an Asian gal that I couldn't understand very well and all she offered me was to set up an appointment at a local Ford dealer at my expense and have them run a diagnostic test to see what might be the problem. My Edge was running fine when I took it in and after the recall "FIX" it seems to have more engine noise and worse fuel economy. I would think twice about having this recall addressed if you Edge is running fine and you are not in a state that still has emissions testing rqmts for license registration. I have owned Ford's all my life and currently have 4 but that may change in the future when replacing vehicles. Thanks for listening and if you have any suggestions how I can improve/restore my fuel economy, I'm all ears. Quote Link to comment Share on other sites More sharing options...
Cobra4fun Posted January 11, 2025 Report Share Posted January 11, 2025 There is another post on this Forum regarding this same exact recall here: Bottom line is that this Recall seems to be creating multiple other adverse issues. 👎 Quote Link to comment Share on other sites More sharing options...
Ar Gerrit Posted February 10, 2025 Report Share Posted February 10, 2025 (edited) Yes, which is why I hadn't done mine yet either. In my state there is no mandatory emission testing anymore (discontinued a few years ago). What seems to happen based on a few other reports, is the vehicle runs less lean. This would make sense, as that happened in other emissions recalls over the years too. It then often means higher fuel consumption but less partially combusted side products and hence lower emissions. There is talk on how busted cats are a side effect of the original issue (lean, but higher amounts of partially combusted particles) configuration. But that is not confirmed yet either. Some people seem to have thrown that into some AI app and now posting screenshots suggesting it as a fact, not realizing the AI might have only picked it up from forum posts like ours where we were speculating. Nevertheless, if true that would mean this recall would give a lower chance of future cat failure vs an immediate higher fuel consumption now. But it is all speculation of course. The fact that Ford is vague means there is some tradeoff somewhere. Edited February 10, 2025 by Ar Gerrit 1 Quote Link to comment Share on other sites More sharing options...
Mads Posted April 24, 2025 Report Share Posted April 24, 2025 Yes, this recall repair will adversely impact your vehicle, based on my experience. I have a 2017 Ford Edge and have received several different recall notices over the last few years. After going to the dealership for this recall repair I've experienced the same issues as another responder, "I got this notice as well for my 2015 Edge. It just so happens that the check engine light has periodically come on and off and am getting codes P2196 and P2198." I had no idea this was a possibility, and considering my check engine light goes on every previous time after leaving the dealership, I decided to take it to a third party. They completed a diagnostic and smoke tests and found nothing. Then an alert "check fuel inlet" started periodically showing up. While my check engine light continued to periodically turn on. Each time I took it into the shop the same codes were presented and sometimes no codes. Eventually I had the fuel neck replaced, and canister purge valve replaced. Check engine light has not turned on again however getting 'check fuel inlet' alert. After reading about this recall and subsequent activity I decided to go back to Ford to ask them to check if the PCM reprogram was faulting or why these issues come and go. They told me they couldn't help without charging a diagnostic fee and additional charges if repair needed. This is the first Ford I've had, and it's been nothing but problems with the dealership and repairs and multiple recalls. Too bad because I really have enjoyed it as a midsize SUV. 1 Quote Link to comment Share on other sites More sharing options...
Chipster Posted July 30, 2025 Report Share Posted July 30, 2025 I wanted to revisit this item as I too have decided to "wait & see" if there were any other members that suffered dire consequences from getting this reprogramming done. If you have had issues not already expressed here please share your experience and what consequences you might have had. Thanks! Quote Link to comment Share on other sites More sharing options...
Cobra4fun Posted July 31, 2025 Report Share Posted July 31, 2025 8 hours ago, Chipster said: I wanted to revisit this item as I too have decided to "wait & see" if there were any other members that suffered dire consequences from getting this reprogramming done. If you have had issues not already expressed here please share your experience and what consequences you might have had. Thanks! After all the horror stories and lack of positive stories on this Recall, I’m definitely not having this done on our Edge. The whole thing is really weird. Quote Link to comment Share on other sites More sharing options...
Chipster Posted August 2, 2025 Report Share Posted August 2, 2025 On 7/31/2025 at 12:26 AM, Cobra4fun said: After all the horror stories and lack of positive stories on this Recall, I’m definitely not having this done on our Edge. The whole thing is really weird. It is weird, and you have to wonder why now after all these years? Quote Link to comment Share on other sites More sharing options...
Cobra4fun Posted November 17, 2025 Report Share Posted November 17, 2025 Anyone have any updates or experience on this recall and their 3.5L V6? Quote Link to comment Share on other sites More sharing options...
Chipster Posted November 17, 2025 Report Share Posted November 17, 2025 I am still holding out. Quote Link to comment Share on other sites More sharing options...
Cobra4fun Posted 13 hours ago Report Share Posted 13 hours ago Just received another recall notice for this 24E10 recall. Does anyone have any positive information to report AFTER having this recall performed? Quote Link to comment Share on other sites More sharing options...
Chipster Posted 11 hours ago Report Share Posted 11 hours ago Me too! What I want to know is: Has anyone that has a state required exhaust gas check required ever had their Edge rejected for out of tolerance levels? Quote Link to comment Share on other sites More sharing options...
