Brandon123 Posted December 13, 2024 Report Share Posted December 13, 2024 First off, yes I know it is less than legal. Second, what is the easiest way to remove the muffler and/or are there any ways that are a big no no? Third, how difficult is it to reattach the muffler after it is removed? Fourth, is it even possible to reattach it, in a way that will make the car inspectable? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted December 20, 2024 Report Share Posted December 20, 2024 Engine is tuned complaint to the OEM exhaust back pressure. From what I've read, modifying the exhaust changes timing (slightly), I think it changes the fuel trims, and the emissions. Believe the engine scavenging is based on the back pressures in the exhaust. Don't know if or how much the systems can compensate. As for how hard, crawl under car and look for yourself. (Dont know what your mechanical ability is.) My recommendation? Don't. Lot of work and you can't drive the car on the street. Quote Link to comment Share on other sites More sharing options...
Brandon123 Posted December 23, 2024 Author Report Share Posted December 23, 2024 (edited) Most my mods aren't street legal. what's one more gonna do lol. Would a change in the timing cause the exhaust to pop? because that's exactly what i'm looking to do. Edited December 23, 2024 by Brandon123 Quote Link to comment Share on other sites More sharing options...
dolsen Posted December 28, 2024 Report Share Posted December 28, 2024 On 12/23/2024 at 4:39 PM, Brandon123 said: Most my mods aren't street legal. what's one more gonna do lol. Would a change in the timing cause the exhaust to pop? because that's exactly what i'm looking to do. popping comes from excess fuel in the exhaust, AKA running rich. I suppose changing timing could do that but I wouldn't rely on that as a way of forcing it because I am not sure it would work. I would think removing the cats is more likely to cause popping than removing mufflers, because the cats cannot burn off the combustion components if they are not installed. Also, you could cut the exhaust at a point that is straight for 6"+ and then use clamps to put the mufflers back on as needed Quote Link to comment Share on other sites More sharing options...
Brandon123 Posted December 30, 2024 Author Report Share Posted December 30, 2024 On 12/28/2024 at 2:30 PM, dolsen said: popping comes from excess fuel in the exhaust, AKA running rich. I suppose changing timing could do that but I wouldn't rely on that as a way of forcing it because I am not sure it would work. I would think removing the cats is more likely to cause popping than removing mufflers, because the cats cannot burn off the combustion components if they are not installed. Also, you could cut the exhaust at a point that is straight for 6"+ and then use clamps to put the mufflers back on as needed Ok thanks. I'll look into that Quote Link to comment Share on other sites More sharing options...
Wargrave Posted January 9, 2025 Report Share Posted January 9, 2025 What year/model do you have? I ran almost a year without a muffler or resonator on my 13 ecoboost. https://youtu.be/CX59Xu08_kY?si=K6zmwCHdqUNOqLFH Quote Link to comment Share on other sites More sharing options...
Brandon123 Posted January 9, 2025 Author Report Share Posted January 9, 2025 7 hours ago, Wargrave said: What year/model do you have? I ran almost a year without a muffler or resonator on my 13 ecoboost. https://youtu.be/CX59Xu08_kY?si=K6zmwCHdqUNOqLFH 2013 sel 3.5 v6 Quote Link to comment Share on other sites More sharing options...
Wargrave Posted January 9, 2025 Report Share Posted January 9, 2025 54 minutes ago, Brandon123 said: 2013 sel 3.5 v6 There are several videos on YouTube of people with the v6 running straight pipes. If you're somewhere that does inspections and need the muffler for it, the easiest way to have it done would be to have an exhaust shop add a flange on the exhaust before the muffler where they cut it off so you can bolt a pipe to the flange or the muffler can be bolted back on for inspections. The v6 seems to drone alone without a muffler though. Quote Link to comment Share on other sites More sharing options...
Brandon123 Posted January 9, 2025 Author Report Share Posted January 9, 2025 Just now, Wargrave said: There are several videos on YouTube of people with the v6 running straight pipes. If you're somewhere that does inspections and need the muffler for it, the easiest way to have it done would be to have an exhaust shop add a flange on the exhaust before the muffler where they cut it off so you can bolt a pipe to the flange or the muffler can be bolted back on for inspections. The v6 seems to drone alone without a muffler though. Ok thanks Quote Link to comment Share on other sites More sharing options...
Brandon123 Posted January 9, 2025 Author Report Share Posted January 9, 2025 1 hour ago, Wargrave said: There are several videos on YouTube of people with the v6 running straight pipes. If you're somewhere that does inspections and need the muffler for it, the easiest way to have it done would be to have an exhaust shop add a flange on the exhaust before the muffler where they cut it off so you can bolt a pipe to the flange or the muffler can be bolted back on for inspections. The v6 seems to drone alone without a muffler though. also im trying to spend as little money as possible because im saving for college. so if you have and cheaper options or ideas that would be apreciates Quote Link to comment Share on other sites More sharing options...
Haz Posted January 9, 2025 Report Share Posted January 9, 2025 Take it from the OG (a general term to praise someone who is an expert at something)... On 12/20/2024 at 6:43 PM, enigma-2 said: Don't. Good luck! 1 Quote Link to comment Share on other sites More sharing options...
Brandon123 Posted February 22, 2025 Author Report Share Posted February 22, 2025 So, mother nature did it for me. Exhaust broke right after the cat and I'm loving it Quote Link to comment Share on other sites More sharing options...
