Edge 3.5L 2013 transmission fluid change interval
AustDev
Hi forum,
After 12 years, I just found that in the manual the change interval is set to each 200k km?!!!
Now am at 300k and already changed the gear oil 4 times, but just curious if that 200k change interval is correct? Seems too high!
I'm using it in Dubai, UAE, so considering the hot and humid weather here, 200k is still correct for gear oil changes?
Thanks all.
Edited by AustDev
  • AustDev changed the title to Edge 3.5L 2013 transmission fluid change interval
