AWD Off message display
This message appears at random times. As soon as the engine is turned on, or while it is running, whether driving fast or slow. The scanner does not show any error or fault code. The PTU oil was changed a while ago before this problem appeared, so it would not be overheating or anything like that. Does anyone have any idea what could be causing this?
And one thing I discovered after a while is that this lag problem in the turn signal only occurs after the AWD off message appears. While it doesn't appear, the turn signals work perfectly. It seems that when the AWD off appears, the entire dashboard lags, turn signals, high and low beams, hazard lights, everything lags/delays.
42 minutes ago, 1004ron said:
What scanner are you using?
Both the forscan and the professional scanner from the mechanic do not show any codes, either with the warning appearing, or in the archived codes, nothing appears in relation to the AWD being turned off
18 minutes ago, Wubster100 said:
I had seen this topic. However, my case is different. It is not about overheating. For example, I can leave my car parked for the entire weekend. When I get in and start the engine, two days later with the car completely cold, the message appears on the screen in the same second. And other times, it appears after driving for several minutes, randomly, without depending on any sudden acceleration, overtaking or anything like that, just normal use.
  • 4 weeks later...
As I mentioned before, even though the car has been without starting for more than a whole day, which would obviously make it cold, as soon as I start the engine, the AWD Off error appears. In this case, could it be the PTU temperature sensor? Is there a separate temperature sensor for it that I can examine or buy a new one? I imagine that if there is, it may be sending wrong information to the ECU and it is disabling the AWD thinking that it is overheating, when in fact it is not.
  • 3 months later...
The AWD was displaying the OFF message because the ABS module with error U3000-49 was causing communication interference on the CAN bus, preventing the wheel speed from being correctly transmitted to the AWD. This caused it to shut down as a protective shutdown.
The solution is mentioned in the original post about the ABS module, which I resolved and detailed below.
  • Thanks 1
