Davidoo Posted June 8 Report Share Posted June 8 I couldn't find a specific topic for this, so I posted it here since I have an ST. I neglected to note the last time I changed the oil. Out of character for me. Of course, I know the oil life monitor will tell me, but I live in Phoenix with intense heat and often change it earlier. Will Forscan show the date the oil life monitor was reset? I don't see that available on the in-dash screen. I use Amsoil and had ordered enough for several oil changes a while ago, so I don't know when I did it last. Thanks! 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted June 8 Report Share Posted June 8 48 minutes ago, Davidoo said: Of course, I know the oil life monitor will tell me, but I live in Phoenix with intense heat and often change it earlier. If I relied on the oil life monitor I'd be changing the oil at around 10K miles, which is twice the mileage I change it at using good brand full synthetic. If I were you I'd change the oil when the oil life monitor is around 50%. Water under the bride but I take the attached photos at each oil change to keep with my Xcel spreadsheet. I don't know, but doubt that Forscan would have that history. 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted June 8 Report Share Posted June 8 I don’t think there is a way, but if there is one, then it would most likely be in the live data section. My oil life is at 14% and it has been 6,599 miles since the last oil change. As @1004ron said, it’s probably best to wait until about 50% oil life. Quote Link to comment Share on other sites More sharing options...
Davidoo Posted June 8 Author Report Share Posted June 8 I'm only 9,000 miles since 2 oil changes ago, so I'm not due yet, just would be nice to know the date. I believe I did it about 3,000 miles ago. I do some long road trips, but in between those I drive the Edge very little. Also, I use Amsoil and they say you can go 20,000, but I never exceed 10,000. 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted June 8 Report Share Posted June 8 I looked in the live data, and I could only find oil life %. It looks like there isn't a way to tell, but you can estimate 0% oil life to be somewhere around 5,000 to 10,000 miles based on driving conditions. Quote Link to comment Share on other sites More sharing options...
omar302 Posted June 9 Report Share Posted June 9 Also, as far as I know, the oil life monitor also takes into account time with the maximum time being 12 months. So if you change the oil as suggested above at 50%, you would be more certainly changing the oil at no more than 5,000 mile or 6 months from when it was last reset. Or you can interpolate the interval you want, knowing that 100% means 10k miles or 12 months. For example, 60% oil life balance would mean 4k miles or 4.8 months. 4 Quote Link to comment Share on other sites More sharing options...
Davidoo Posted June 10 Author Report Share Posted June 10 Thanks for the responses. I have downloaded Forscan before, but I don't have the cable yet, and thought if it would work now would be the time to invest in it. 1 Quote Link to comment Share on other sites More sharing options...
Yaga1973 Posted 10 hours ago Report Share Posted 10 hours ago On 6/8/2025 at 5:16 PM, Davidoo said: I'm only 9,000 miles since 2 oil changes ago, so I'm not due yet, just would be nice to know the date. I believe I did it about 3,000 miles ago. I do some long road trips, but in between those I drive the Edge very little. Also, I use Amsoil and they say you can go 20,000, but I never exceed 10,000. One thing to consider, even with a high quality oil like Amsoil, is that there are many fine screens in the engine that filter oil. Varnishes may still develop, even with a high quality oil, and cause them to start clogging. This is especially important for the filter screens on the oil lines going to the turbos. Just something to be aware of. 1 Quote Link to comment Share on other sites More sharing options...
