bogmanglen Posted June 23, 2025 Report Share Posted June 23, 2025 (edited) All of a sudden, the AC quit yesterday. Forscan shows U0401 in the HVAC module. Fan blows, compressor clutch not engaged. 2021 Edge SEL 2.0 Any help appreciated! Edited June 23, 2025 by bogmanglen 2 Quote Link to comment Share on other sites More sharing options...
Haz Posted June 23, 2025 Report Share Posted June 23, 2025 @bogmanglen: The 2021 Edge Workshop Manual diagnostic Pinpoint Test AA directs to perform a Powertrain Control Module (PCM) Self Test scan-tool/Forscan procedure to see if any PCM DTC(s) are revealed. PINPOINT TEST AA: U0401:00, U0401:82, U0422:68, U0422:81, U0452:82 Introduction DTC Fault Trigger Conditions DTC Description Fault Trigger Condition HVAC U0401:00 Invalid Data Received From ECM/PCM 'A': No Sub Type Information Sets when the HVAC control module receives invalid network data from the PCM . HVAC U0401:82 Invalid Data Received From ECM/PCM 'A': Alive/Sequence Counter Incorrect/Not Updated Sets when the HVAC control module receives invalid network data from the PCM . HVAC U0422:68 Invalid Data Received From Body Control Module: Event Information Sets when the HVAC control module receives invalid network data from the BCM . HVAC U0422:81 Invalid Data Received From Body Control Module: Invalid Serial Data Received Sets when the HVAC control module receives invalid network data from the BCM . HVAC U0452:82 Invalid Data Received From Restraints Control Module: Alive/Sequence Counter Incorrect/Not Updated Sets when the HVAC control module receives invalid network data from the RCM . Possible Causes Suspect module AA1 CHECK FOR DIAGNOSTIC TROUBLE CODES (DTCS) FROM THE MODULE SENDING INVALID DATA Ignition ON. Using a diagnostic scan tool, carry out the self-test for the module in question sending the invalid data. Are any Diagnostic Trouble Codes (DTCs) present from the module sending the invalid data? Yes DIAGNOSE the module sending the invalid data. REFER to the appropriate section in the Workshop Manual. No DIAGNOSE the observable symptom present. REFER to the appropriate Symptom chart in this section. If yes. report the PCM DTC(s) back here. If no, then a symptom-based diagnostic Pinpoint Test L, which evaluates many potential contributing factors, will need to be employed. Pinpoint Test L and several -- but not all -- of its supporting documents are attached below for you to assess, if you wish to personally pursue the solution or if you might choose to have a professional technician address it on your behalf. Good luck! PINPOINT TEST L - THE A-C (AIR CONDITIONING) IS INOPERATIVE - NO DIAGNOSTIC TROUBLE CODES (DTCS) - 2021 Edge Workshop Manual.pdf Climate Control System - System Operation and Component Description - 2021 Edge Workshop Manual.pdf Refrigerant System Tests - 2.0L EcoBoost - General Procedures - 2021 Edge Workshop Manual.pdf 3 Quote Link to comment Share on other sites More sharing options...
bogmanglen Posted June 26, 2025 Author Report Share Posted June 26, 2025 Looks like I may need a compressor...Oh well, I have manifold gauges and a vacuum pump... Does anyone happen to have the workshop pages for compressor replacement? 2021 2.0 SEL Thanks! Quote Link to comment Share on other sites More sharing options...
Haz Posted June 26, 2025 Report Share Posted June 26, 2025 @bogmanglen: Relevant sections from the 2021 Edge Workshop Manual are attached below as PDF documents... Good luck! Air Conditioning (A-C) Compressor - 2.0L EcoBoost - Removal and Installation - 2021 Edge Workshop Manual.pdf Air Conditioning (A-C) Compressor Belt - 2.0L EcoBoost - Removal and Installation - 2021 Edge Workshop Manual.pdf Fender Splash Shield - Removal and Installation - 2021 Edge-MKX Workshop Manual.pdf 3 Quote Link to comment Share on other sites More sharing options...
bogmanglen Posted June 26, 2025 Author Report Share Posted June 26, 2025 Thank you for your terrific contributions to this community, Haz! 1 2 Quote Link to comment Share on other sites More sharing options...
bogmanglen Posted June 29, 2025 Author Report Share Posted June 29, 2025 (edited) Looking further into it, -- We have a U0401. -- Ran a key off self test, got DTC P1464 AC demand out of range. AC clutch did not engage -- static pressure is 62 psi at measured ambient 75 F on both sides R-1234yf table says it should be 82.2 PSI at that temp. -- New Note: Manifold guage reads 62 PSI at 75F, AC_PRESS PID reads 105...out of range? Would that stop compressor clutch? Calls for Pinpoint test A -- ACCCLT_ALW (AC clutch allow) is NO on Forscan. All other Forscan AC PID's are OK or yes. At this point, I'm thinking either a bad HVAC module (due to the U0401) or low refrig (based on static pressure). Gotta figure our why clutch is not engaging. Any thoughts appreciated. Edited June 29, 2025 by bogmanglen addition to AC_PRESS Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted August 27, 2025 Report Share Posted August 27, 2025 Ever figure this out? (Low freon will keep the system from engaging.) Quote Link to comment Share on other sites More sharing options...
