2015 Greygoose Posted July 19 Report Share Posted July 19 Hi guys, Helping out my father in law Who got to for a ride by a local garage. Picked up his car from the garage and instruments panel was not working, amongst other things. Quicker to state what is working. Starts, runs and drives. Also working are, power seats' rear windows, dome lights and power fit locks. I've visually inspected all fuse. All are good. Alternator was pulling 15 volts. In the process of changing that now. Any help would be greatly appreciated. Thank you. 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted July 20 Report Share Posted July 20 To get a better idea of what’s going on, could you share a few more details? What year is the Edge? What engine and trim is it (SE, SEL, Limited, etc.)? Do you know exactly what work the garage did before the problems started? Did the issues start right after picking it up, or was there a delay? When you say the instrument panel isn’t working, is it totally dead (no lights, gauges, warning lights), or are some parts still working? Any other electronics not working, like the radio, HVAC, headlights, etc.? You checked all the fuses visually? Did you test them with a multimeter or just look at them? Also, about the alternator, was it overcharging (15V seems a bit high)? Curious what made you decide to swap it out. 1 Quote Link to comment Share on other sites More sharing options...
2015 Greygoose Posted July 21 Author Report Share Posted July 21 It's a 2015 SEL with the 2.0. I'm not certain what work the garage did. My father-in-law stated that the car was turned over to him with the issues. Instrument panel is completely dead. No other electronics work. No HVAC, radio, headlights, tail lights, turn signals, nothing. Only visually inspected fuses. Will be using a multimeter next time I'm out to install the new alternator. Swapping the alternator as I feel that 15V may be overcharging the battery. Looking for a place to have the old alternator tested, now that I have it out, before installing a new one. 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted August 27 Report Share Posted August 27 You ever figure this out? I'd have thought the alternative putting out 15v would have made it a battery problem (that and the multiple failures.) Quote Link to comment Share on other sites More sharing options...
2015 Greygoose Posted August 28 Author Report Share Posted August 28 Yes, and no. I figured out the alternator is good. Tested at 14.6 volts. Was able to return to Amazon. I bought a wee little fuse tester and checked all fuses, under the dash, under the hood and also the ones hiding underneath those. I truly don't know where to go from here. Any help on which direction to go from here would be much appreciated. Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted August 28 Report Share Posted August 28 scan for codes? Quote Link to comment Share on other sites More sharing options...
2015 Greygoose Posted September 10 Author Report Share Posted September 10 I did. It came up with 5, although really only 2 that were recurring. P0113 > Intake air temp. #1 circuit high P25B0 > Fuel level sensor "A" stuck or has a malfunction. I feel bad that I haven't had time to work on it. Not really sure where to go from here. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted September 12 Report Share Posted September 12 Stupid question, did you ever check to see if the instrument cluster is plugged in? 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted September 12 Report Share Posted September 12 1 hour ago, enigma-2 said: Stupid question, did you ever check to see if the instrument cluster is plugged in? The IPC is a canbus module, so @2015 Greygoose should try to use their scan tool to see if there is any communication. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted September 12 Report Share Posted September 12 (edited) 16 hours ago, Wubster100 said: The IPC is a canbus module, so @2015 Greygoose should try to use their scan tool to see if there is any communication. Believe he did. Only came up with P0113 > Intake air temp. #1 circuit high P25B0 > Fuel level sensor "A" stuck or has a malfunction. My first reaction was weak battery or defective BCM. But he didn't find any codes. Reason I suspected possible unplugged cluster is that it happened after getting car back from mechanic. ....Not that a mechanic would ever deliberately do anything underhanded. (grunt) . Edited September 12 by enigma-2 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted September 13 Report Share Posted September 13 If the IPC is unplugged, then there should be codes from other modules for lost communication with IPC. Unless it is a bad code reader. Quote Link to comment Share on other sites More sharing options...
2015 Greygoose Posted September 16 Author Report Share Posted September 16 Next time i go work on it I'll definition check if the instrument cluster is plugged in. Where abouts is would I find that plug? I really don't know where to go from here. I'm thinking of just bringing it in to a shop to see if they can figure it out. I just need to know what to change. Electrical diagnosis is my kryptonite. I appreciate any direction. 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted September 16 Report Share Posted September 16 What kind of scan tool did you use? What were the other intermittent codes? Quote Link to comment Share on other sites More sharing options...
2015 Greygoose Posted September 23 Author Report Share Posted September 23 Only the 2 code came up. I use a Creader 3001 Quote Link to comment Share on other sites More sharing options...
