TourGuide Posted September 6 Report Share Posted September 6 (edited) I love my 2.7 for what it is and how much fun I get out of it. The more I learn about the oil pump belt in these engines the more concerned I get. I am putting a link here to a teardown video of another Ford engine - the 3 cyl. 1.5 with the same style belt at 70k. Teardown video. The condition of this belt, at that mileage is - well - verification of the problem I think. Edited Saturday at 02:24 PM by TourGuide Quote Link to comment Share on other sites More sharing options...
1004ron Posted September 6 Report Share Posted September 6 What Model/Year do you have? - Please add that to your profile signature - https://www.fordedgeforum.com/settings/signature/ Can you confirm that the 2.7L V6 in the Ford Edge has a belt driven oil pump. Quote Link to comment Share on other sites More sharing options...
1004ron Posted Saturday at 11:33 AM Report Share Posted Saturday at 11:33 AM A little research confirms that the 2019 ST and onwards use the belt driven oil pump. https://ford.oempartsonline.com/oem-parts/ford-engine-timing-belt-jt4z6b651a?c=Zz1lbmdpbmUmcz1vaWwtcHVtcCZsPTgzJm49QXNzZW1ibGllcyBQYWdlJmE9Zm9yZCZvPWVkZ2UmeT0yMDE5JnQ9c3QmZT0yLTdsLXY2LWdhcw%3D%3D Do we have any idea on how these are holding up? - haven't heard of any reports on this forum, but that could be that there would be very few at 100K miles or more. Quote Link to comment Share on other sites More sharing options...
TourGuide Posted Saturday at 02:30 PM Author Report Share Posted Saturday at 02:30 PM The only way to get a visual on this belt is to drop the oil pan, or disassemble the entire front of the engine. This video IS an example of an engine that had maintenance neglected - the concern is clearly the mileage of this engine. I look at this video and think - crap - MY engine has 80k on the clock. I was planning to go to 100k before doing a timing set and replace this belt then. Quote Link to comment Share on other sites More sharing options...
1004ron Posted Saturday at 05:21 PM Report Share Posted Saturday at 05:21 PM What's behind your thoughts of changing the timing chain around 100K? I've got 117,000 miles on my 2016 2.7L and don't have plans to change the timing chain, but might reconsider that depending on what I hear back from you. Quote Link to comment Share on other sites More sharing options...
TourGuide Posted Sunday at 12:14 PM Author Report Share Posted Sunday at 12:14 PM (edited) The chain guides system as well as the chain itself are all wear items to a degree (moving parts). In addition to changing out that oil pump belt - which in my case is the main motivation personally - changing out those items ensures that this engine goes the distance for me as I plan to drive this vehicle as far as it will take me. It is a big job since the entire front of the engine comes off - so preventative maintenance I guess is the ultimate goal. My economic assessment is that it is cheaper to maintain/repair than buy new these days. I'll see - maybe someone will arrive on the scene with an EV that is reasonably priced - don't laugh - it could happen.... Edited Sunday at 12:18 PM by TourGuide more thoughts Quote Link to comment Share on other sites More sharing options...
Yaga1973 Posted Wednesday at 06:22 PM Report Share Posted Wednesday at 06:22 PM On 9/7/2025 at 8:14 AM, TourGuide said: The chain guides system as well as the chain itself are all wear items to a degree (moving parts). In addition to changing out that oil pump belt - which in my case is the main motivation personally - changing out those items ensures that this engine goes the distance for me as I plan to drive this vehicle as far as it will take me. It is a big job since the entire front of the engine comes off - so preventative maintenance I guess is the ultimate goal. Do you plan on replacing the timing chain sprockets as well? I'm used to the motorcycle world for when you replace your rear chain, you should replace the sprockets too so that you don't cause premature wear on the new chain. Quote Link to comment Share on other sites More sharing options...
TourGuide Posted 13 hours ago Author Report Share Posted 13 hours ago If I end up going for this repair and the car has lasted that long trouble free - I would do the sprockets too. The labor involved in taking the front of the motor apart would almost make skipping that step silly I think. Quote Link to comment Share on other sites More sharing options...
