my 2012 edge Posted December 16, 2025 Report Share Posted December 16, 2025 on my 2012 ford edge all warning lights came on brought it to ford they said code u3000. which is a abs module which is on backorder with no eta. can i rebuild the factory one orvis there a aftermarket available Quote Link to comment Share on other sites More sharing options...
my 2012 edge Posted December 20, 2025 Author Report Share Posted December 20, 2025 any ideas? Quote Link to comment Share on other sites More sharing options...
edjunior Posted December 21, 2025 Report Share Posted December 21, 2025 I think this is going to be a tough one. Hang tight...maybe someone will be along with some help. It's way out of my league. Quote Link to comment Share on other sites More sharing options...
my 2012 edge Posted December 21, 2025 Author Report Share Posted December 21, 2025 ok thanks Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted Sunday at 07:25 PM Report Share Posted Sunday at 07:25 PM Ever fix this? There's a weak possibility that it can also be caused by a weak battery (low voltage), corroded connector (or bad wiring) or a bad wheel bearing. Quote Link to comment Share on other sites More sharing options...
my 2012 edge Posted Monday at 11:23 AM Author Report Share Posted Monday at 11:23 AM i havent fixed it. i brought it to ford they said its the abs module which is on backorder. still driving it just annoying lights and chimes. very fustrating Quote Link to comment Share on other sites More sharing options...
my 2012 edge Posted Monday at 11:24 AM Author Report Share Posted Monday at 11:24 AM i also replaced the battery which made no difference Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted Monday at 05:57 PM Report Share Posted Monday at 05:57 PM I was just reading on a different forum that the 2012 ABS module has been discontinued by Ford. This site sells used parts: https://share.google/Rh2QyDB3zZrPIfQ70 Quote Link to comment Share on other sites More sharing options...
my 2012 edge Posted Tuesday at 11:54 AM Author Report Share Posted Tuesday at 11:54 AM i need to find someone that can rebuild mine. otherwise i have to reprogram it thru ford Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted Tuesday at 08:38 PM Report Share Posted Tuesday at 08:38 PM Perhaps here: Truck - Cars ABS Module Repair Service - 5-Star Repairs https://share.google/QD0UzCAQaOQUe7nRr Quote Link to comment Share on other sites More sharing options...
electblu Posted Wednesday at 01:23 AM Report Share Posted Wednesday at 01:23 AM (edited) I have a similar issue on my 2011 Edge. Unfortunately I have one that was built in August of 2010 so it uses a BT4Z-2C219-A which has been discontinued. Does your 2012 use the newer DT4Z-2C219-B? I have been looking at the ones on eBay but they seem to use refurbished and remanufactured interchangeably. Not sure I want to go through the hassle of replacing it with a used part just to have it failing after a couple of months. I just hit 200,00 and was planning on keeping the car as I love it, but now I may have to rethink that. Edited Wednesday at 10:37 AM by electblu Quote Link to comment Share on other sites More sharing options...
my 2012 edge Posted Wednesday at 11:19 AM Author Report Share Posted Wednesday at 11:19 AM im not sure part no. i was told a used one has to be repogrammed. is that true Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted Wednesday at 05:03 PM Report Share Posted Wednesday at 05:03 PM Yes, the modules are VIN-specific and require programming. Quote Link to comment Share on other sites More sharing options...
my 2012 edge Posted Thursday at 02:23 PM Author Report Share Posted Thursday at 02:23 PM if i rebuild mine do i have to reprogram it Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted 2 hours ago Report Share Posted 2 hours ago (edited) No. Not if you're using the same parts. The software is stored on a chip that retains its programming when deenergized. If you were to change out the circuit board, then yes. The replacement circuit board would contain the programming from the old car. . Edited 2 hours ago by enigma-2 Quote Link to comment Share on other sites More sharing options...
