2016 ford edge 4 cyl. Twin turbo oil
Warren57
Yes, your 4-cylinder 2.0L EcoBoost engine  requires SAE 5W-30 oil.
5W-20 oil will thin out at operating temperatures and will not maintain a protective film between moving metal parts.
Most critically, the turbos are at greatest risk. They spin at +150,000 RPM and uses oil to cool and lubricate the bearings. 5W20 will break down (get too thin) under this extreme heat, leading to bearing wear or turbo failure.
Replace it immediately with 5W30.
