2014 Ford Edge front wipers always on after windshield replacement
Welcome.
Its likely that the installer trashed the rain sensor - have you tried it with it not in Auto?
Who installed it, AutoLite SafeLite?
Edited by 1004ron
SafeLite botched a chip repair and three windshield replacements following that.
The insurance instructs the installers to use the cheapest glass, unless you insist on OEM.
From your description it appears they've fouled the rain sensor and it will  require a new one, and a possible a new windshield if it an issue with the cheap Chinese one they typically use.
Edited by 1004ron
  • 1004ron changed the title to 2014 Ford Edge front wipers always on after windshield replacement
This model/level doesn't have "auto" on the wiper switch.  So I'm going to order a new switch.  It looks easy enough to replace.  Pretty sure this will do it.
As far as the serpintine belt, thus one routes to the ac compressor and alternator.  Very difficult.   We used the tool to release tension, additionally 2 large screwdrivers and crowbars to move the tensioner further than the tool would take it.  Then we had to pry the belt around the tension pulley.Never have I had this level of difficulty for a belt.
Switch is due next week, Thursday.
51 minutes ago, JohnT396 said:
My son in law found a menu setting called courtesy wipe.  He changed the setting so the problem seems to gone away.  Could have been changed when the glass was replacef..
Glad that a solution was found, even if it doesn't make much sense.
The courtesy wipe is a feature that provides an extra wipe of the windshield a few seconds after you finish using the windshield washer fluid.
Agree...it doesn't make sense.  I can't possibly imagine what happened, but something went haywire with the replaced windshield.
