Adding Ford P&P alarm and can't find the Gateway
Hello all.  I have a 2021 Edge Titanium and am trying to install the Ford Alarm ML3Z-19A361-A.  I am suppose to install a T harness in between the vehicle harness and the Gateway Module.  I found a YouTube video for a 2020 showing the module just right of the steering, however, the two bolts holding the module in the video are empty in my Edge.  Please help me locate the Gateway Module.
Thank you,
Paul
Look for the OBD-II port. (Where you plug in a scan tool.) This port is physically attached right to the bottom of the Gateway Module assembly.
If you follow your OBD-II port up behind the plastic trim, your hand will go straight to the GWM.
To access the module you need to remove the lower plastic trim panel located underneath the steering wheel. (It's held in place by a few plastic clips and 7mm or 10mm screws.)
Once the panel is removed, look up to the right of the steering shaft. You will see a rectangular plastic module box with multiple prominent wiring harnesses plugged into it.
This is the exact location where you will perform the "T-harness" pass-through installation.
Posted (edited)
Is there any chance it could be part of the fuse block on the 21?  If so, it is tucked up to the left side of the dashboard. Also, this black plug is not the same size as the one in the kit.
Edited by e7ats
