schuyler Posted June 16 Report Share Posted June 16 2008 Ford Edge 160k AWD. Carrier bearings have just been replaced. I am getting shaking pretty much every time it's accelerating at ~40mph and 2500 rpms. The problem gets better after the bearings are replaced, but it has never gone away completely, so the problem must be greater than a bad carrier bearing. Where the driveshaft goes into where the drivehaft mounts to the PTU looks off-center (where the camera is pointed), and I am wondering if it's an engine or transmission mount. I think this becasue when I pry on the PTU, the whole engine/trans has a lot of movement. It doesn't seem related because it's the drive shaft that's bouncing, but I figured it could be causing a driveshaft angle to be off. driveshaft.mp4 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted June 22 Report Share Posted June 22 (edited) Have you checked the cars CV joints? Worn inner CV joints can cause a shudder during acceleration. If the shudder disappears when you take your foot off the gas pedal and let the car coast at 40 mph, check the joints. The second thing I'd check is the AWD driveshaft center support bearing. Your 2008 AWD has a two-section driveshaft running to the rear wheels. The two sections connect through a bearing at the center of the two. At 160k miles, its possible that the rubber dampener around the center bearing has worn which causes the shaft to wobble at the specific speed you mentioned. You can check this by shaking the driveshafts near the middle bearing. There should be no play. Any play at all is wear. Anotheg possibly as reported in the 150 forum that they traced this to the torque converter clutch. You can test this by accelerating to ~40 mph and when experiencing the shake near a shift point, lightly tap the brake pedal with your left foot while keeping your right foot on the gas. If the shaking stops instantly, the torque converter clutch is probably slipping. . Edited June 22 by enigma-2 Quote Link to comment Share on other sites More sharing options...
1004ron Posted June 22 Report Share Posted June 22 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted June 23 Report Share Posted June 23 Post reminded me of a song from Little Anthony and the Imperials. "Shimmy, Shimmy, Koko Bop." (Before your time, don't worry about it, mind wondering.) (Again.) (grunt) Quote Link to comment Share on other sites More sharing options...
schuyler Posted June 24 Author Report Share Posted June 24 On 6/22/2026 at 5:15 AM, 1004ron said: I know you can't tell from the video but its not "slight", its a very hard banging and has to do with the rpms ~2,000. Quote Link to comment Share on other sites More sharing options...
