beachparty Posted August 12, 2009 Report Share Posted August 12, 2009 Does anyone know if the spare tire could be mounted underneath the car to free up space in the cargo area? Quote Link to comment Share on other sites More sharing options...
pxb006 Posted August 12, 2009 Report Share Posted August 12, 2009 Not sure how much useful space you would gain by doing that, but I can't think of a good method to do so. Quote Link to comment Share on other sites More sharing options...
bbf2530 Posted August 12, 2009 Report Share Posted August 12, 2009 Does anyone know if the spare tire could be mounted underneath the car to free up space in the cargo area? Hi beachparty. :D While almost anything can be done with enough money, know-how and time, it is doubtful that this could be reasonably accomplished. First problem, it is unlikely that there is enough room to tuck a spare tire (along with the necessary carrier and other hardware) under the back end of an Edge. Since the Edge was not designed with an under-car spare in mind, there will be too many under-vehicle components in the way and not enough room. Second problem, designing a carrier and the necessary hardware to raise, store, lower etc., a spare tire. Not saying it is impossible, just much more work than most people will be willing to take on for the limited benefit. Good luck. :beerchug: Quote Link to comment Share on other sites More sharing options...
ablb Posted August 12, 2009 Report Share Posted August 12, 2009 (edited) Does anyone know if the spare tire could be mounted underneath the car to free up space in the cargo area? Pay a visit to a local CUSTOM muffler shop, that HUGE stock cat back will have to go. Probably end up with a true dual exhaust running down the sides with mufflers located in front of the wheels. Like this http://www.louscustomexhaust.com/ should cost a few hundred $'s Then get a spare tire set-up of off something like a F150. like this. http://www.forddirectonline.com/partlocato...amp;catalogid=2 Be sure to measure twice, maybe 3 times and don't forget to measure how far DOWN the spare will hang. ab Edited August 12, 2009 by ablb Quote Link to comment Share on other sites More sharing options...
kempie Posted August 13, 2009 Report Share Posted August 13, 2009 Get a rack for the top and put the spare up there. Quote Link to comment Share on other sites More sharing options...
carcondo Posted September 23, 2009 Report Share Posted September 23, 2009 I have turned my spare over so I can use the offset of the wheel as storage. Bit of a PITA when you want to check the tire pressure is only downside. Quote Link to comment Share on other sites More sharing options...
