Custom Search
Sign In  Log in with Facebook
Create Account
Click here to signup now
Guest Message by DevFuse
The Ford Edge ST Has Been Unveiled.  More here.
2015-2017 Front Vista Roof
Best Answer Coolpooler , Yesterday, 09:05 PM
<sigh> So my $1465 quote turned into $1542.15 with freight (The joys of living 3 hours from the nearest major city) so including GST $1619.26, still cheaper than the dealer by about $100+... :drop:
It was the Rev C glass and I followed MACT's video linked above (Many thanks to MACT for taking the time to make it and roots57 for posting it in this thread). I had the old glass off and the new one in, functioned and cleaned in 45 minutes.
A few points to add for the install:
I didn't bother taking the -ve terminal off so I didn't reinitialize the sunroof, and I was careful not to move the guides more than absolutely necessary.
The front bolts are a combo Torx25/ 8mm hex so when I re-installed them I held them in the 8mm socket on a short extension with a bit of masking tape wrapped around the end to get them started and avoid the hassle of fishing them out as in the vid. ;)
If you have an LED headlight it is super handy to give you light in the recesses of the bolt holes and made lining everything up trivial.
Since I have the old glass now easily accessible I will be taking some close up pics of the crack and the "impact" point and forward those results to Ford Canada and see if I get any satisfaction from them; I'm not counting on it though.
Vipervenom: I would do the front glass myself but it only adds .4-.6 hrs on the bill so if they have the headliner and all the other stuff out it's really not that much to add overall. You might be able to negotiate a bit and see if that will save the difference.
Go to the full post
  • Please log in to reply
11 replies to this topic
#1 OFFLINE   Coolpooler
Coolpooler
    New Edge Member
  • Edge Member
  • 9 posts
  • Region:Canada Prairie Provinces
  • Edge's Year:2017
Posted 09 January 2018 - 04:19 PM
OK, I have the dreaded crack in the front glass of our new Edge's Vista Roof and since Ford Corporate are being dicks and not honoring their warranty I have two questions that I'd like your inestimable help with. I'm thinking of replacing the front glass myself as it looks to be fairly straightforward.
  1. Is the part # FT4Z-58500A18-C the complete frame or is it the glass only? The pics on every site I could find wasn't clear and not the actual part itself but a line drawing
  2. Is there anything different in removal between the 15-up vs the 2008-up glass? I know the older models could be removed with just 6 bolts, is that the case with the newer version as well?
Any other voodoo I should be aware of before I attempt this? OK, three questions... :)
#2 OFFLINE   WWWPerfA_ZN0W
WWWPerfA_ZN0W
    Ford Edge Legal Resident
  • Edge Platinum Member
  • 8,381 posts
  • Region:U.S. Northeast
  • Edge's Year:Decline
Posted 09 January 2018 - 06:56 PM
FT4Z-58500A18-C looks like the front glass only.  No glass insurance?  Your auto insurance should cover it, no?
#3 OFFLINE   roots57
roots57
    New Edge Member
  • Edge Member
  • 275 posts
  • Region:U.S. Pacific Coast
  • Edge's Year:2016
Posted 09 January 2018 - 07:06 PM
Here's a video from MACT on servicing the pano moon roof which includes removal of the glass:
Is this what you found too?  EXPENSIVE!!!  $750-$950 each panel.
I'd sure hate to have to buy one out-of-pocket for a brand new car, how come they are not covering it under warranty, did you damage it yourself or did it just crack?  What about your insurance, glass coverage may cover it even if it was damaged by mistake.  There may be a deductible as your insurer may not consider it safety glass and could treat the same as something like body damage due to collision.  I just emailed State Farm to make sure mine is covered, got me curious after seeing that price!
Anyway, looks like the p/n for the front (moveable) glass panel is FT4Z-58500A18-C and it replaces FT4Z-58500A18-A so it looks like you have the right part number:
https://www.oemfordp...WVyXzEmYT1mb3Jk
Good luck!
(sorry WWWPerfA_ZNOW you must have posted right before me)
*Update - State Farm just confirmed that it would be a glass claim covered under my policy, should mine crack/break so hopefully you have the same sitch.
Edited by roots57, 09 January 2018 - 07:44 PM.
  • WWWPerfA_ZN0W and Coolpooler like this
#4 OFFLINE   Coolpooler
Coolpooler
    New Edge Member
  • Edge Member
  • 9 posts
  • Edge's Year:2017
Posted 10 January 2018 - 10:45 AM
Well, crap. That was my suspicion and explains why the dealer adds close to $1000 labour. Ford is saying that they won't cover it as it was due to an impact, but if it was it was incredibly small, as you can't see it with the naked eye. I believe it let go while we driving home Christmas Day , when the temps were in the low -20s.
I'll be taking it to a glass shop for a second opinion. Assuming the worst, I was hoping that I could buy the complete front glass sub-assembly and just bolt it in... Full glass coverage in Alberta adds roughly $200/yr to our insurance and your rates go up after 1 claim so it's essentially useless, except in this case... :drop:
  • WWWPerfA_ZN0W likes this
#5 OFFLINE   Coolpooler
Coolpooler
    New Edge Member
  • Edge Member
  • 9 posts
  • Edge's Year:2017
Posted 12 January 2018 - 03:12 PM
Update: Got three quotes and it seems I was mistaken. The front glass is a sub-assembly with the frame and not just a pane of glass. The least expensive quotes here were $1465 CAD so it looks like I'll be ordering one and installing a la MACT's video on Youtube. While I'm at it I will give the tracks a good looking over and lubing if necessary (I hope not with only 3600 miles on the clock....). I will keep the original, clean it out and maybe try my hand at building a carbon fibre panel on it.
#6 OFFLINE   vipervenom550
vipervenom550
    New Edge Member
  • Edge Member
  • 8 posts
  • Edge's Year:2015
Posted 12 January 2018 - 10:56 PM
Let me know how the swap goes I my movable and non movable piece just cracked.  Have to pay someone to change the non movable but maybe I can save some money by doing the movable myself.  I have been told the headliner will need to be dropped to change the back non movable piece.  Going to be very pricey to fix all this glass.
#7 OFFLINE   roots57
roots57
    New Edge Member
  • Edge Member
  • 275 posts
  • Edge's Year:2016
Posted 14 January 2018 - 12:43 AM
That's a damn shame that this wasn't something either the dealership or your insurance wouldn't cover...especially with only 3600 miles so far...just wrong
#8 OFFLINE   Coolpooler
Coolpooler
    New Edge Member
  • Edge Member
  • 9 posts
  • Edge's Year:2017
Posted 17 January 2018 - 06:30 PM
I'm picking up the glass today; from a body shop in town as the dealer wanted $1600 +tax! The plan is to put it in tonight.
#9 OFFLINE   omar302
omar302
    Ford Edge Addict
  • 1,712 posts
  • Region:Middle East
  • Edge's Year:2011
Posted Yesterday, 12:14 AM
I remember reading somewhere that the 2016 Edge Vista roof switched to a "dual panel" type for sound insulation. Also, there is at least 1 revision to the the part number, Tasca Parts shows  FT4Z-58500A18-C as the latest & that it replaces FT4Z-58500A18-A. So make sure you get the latest revision.
#10 OFFLINE   Coolpooler
Coolpooler
    New Edge Member
  • Edge Member
  • 9 posts
  • Edge's Year:2017
Posted Yesterday, 09:05 PM   Best Answer
Edited by Coolpooler, Yesterday, 09:06 PM.
  • WWWPerfA_ZN0W, omar302 and MaX83_ZA like this
#11 OFFLINE   WWWPerfA_ZN0W
WWWPerfA_ZN0W
  • 8,381 posts
Posted Today, 07:24 AM
Whew, glad that is over with!  :thumbsup:
#12 OFFLINE   omar302
omar302
    Ford Edge Addict
  • 1,712 posts
  • Edge's Year:2011
Posted Today, 08:03 AM
Van you see the edge of the glass if it is clearly laminated glass? I have not seen one myself (laminated vista roof) so I don't know if it looks like the front side windows where it is clear that they are 2 thin layers with a thinner insert between them.
