Moderator-
PTU not covered by the powertrain warranty??
akirby replied to centeryourmind's topic in All Wheel Drive (AWD)
I think whomever was called at Ford was just agreeing with the dealer without doing any investigation. If you can't get the first dealer to change their mind go find another one. -
I need an x plan pin!!!! want lease a ford edge!!
akirby replied to bfills's topic in Buying, Leasing & Ordering
Cool. So you know Doug........ Do they still let you keep the spiff check? Can't beat that deal. -
So what was your cost and where did you get it? You still get the rebates on top of X plan so you'd have to negotiate a price at dealer invoice minus rebates plus $100 doc fee. It can be done on certain vehicles but beware of dealers who say they can beat x plan but then they keep the rebates or add really high doc fees or other add-ons or they rip you off on the trade-in to make up the difference. Yes, you get the rebates in addition to the X plan price. -
Ask the dealer for a quote on the same vehicle on X plan. No way for us to tell one way or the other. -
polishing plastic chrome wheels
akirby replied to richy's topic in Appearance - Detailing, Wash & Wax
Exactly. You can remove them (once) but you'll never get them back on. -
If you mean the chrome clad wheels - downright impossible. -
http://www.fordedgeforum.com/index.php?/topic/7332-inside-info-on-mft-development/page__view__findpost__p__58713 You can trust Waldo on this one. BTW - this doesn't mean that Ford isn't still paying Bsquare under the contract terms even if they decided to redo the software in house. Happens all the time.
This doesn't explicitly say the PTU seal should be covered but it's darn close. Maybe a dealership employee has some experience with this. If Ford insists it's not covered your only recourse would be small claims court. (1) Your vehicle’s Powertrain components are covered for five years or 60,000 miles, whichever occurs first. The extended coverage applies to the Engine: all internal lubricated parts, cylinder block, cylinder heads, electrical fuel pump, electronic engine control unit, engine mounts, flywheel, injection pump, manifold (exhaust and intake), manifold bolts, oil pan, oil pump, seals and gaskets, thermostat, thermostat housing, timing chain cover, timing chain (gears or belt), turbocharger/supercharger unit, 10 valve covers, water pump; Transmission: all internal parts, clutch cover, seals and gaskets, torque converter, transfer case (including all internal parts), transmission case, transmission mounts; Front-Wheel Drive: axle shafts, bearings (front and rear), center support bearing, drive shafts, final drive housing (including all internal parts), hubs-automatic front locking (four-wheel drive), locking rings (four-wheel drive), seals and gaskets, universal and constant velocity joints; -
I wasn't sure but I do know that some engines don't have them. 2000 Lincoln LS V8 e.g. - or was it the V6? One of them for sure did not have a PCV valve.
I believe there was a PCM reflash that was supposed to help with the rollback. Perhaps it was applied during a dealer visit.
Doesn't sound right. I'd get it checked out by a mechanic and/or just go ahead and replace the pads/turn the rotors. This is normal and is a function of how the torque converter is designed (stall speed). All traditional automatic transmissions do this to some degree. In most vehicles the engine idle speed is enough to "engage" the torque converter and prevent rollback. In the Edge the stall speed is higher so engine idle speed is not enough to keep the vehicle from rolling backwards. You get used to it.
Do you have a factory 5/60K powertrain warranty or not? If not then you must have an extended warranty and that could have a $100 deductible. I don't remember when they changed the powertrain warranty to 5/60K. There is no deductible with the factory warranty. Ask the dealer to show you where this is documented.
Turn automatic headlights off???
akirby replied to CCL123's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
The switch that turns the lights on and off. To the left of the steering wheel. -
PLEASE TELL ME HOW TO USE THE AV INPUTS!!!
akirby replied to Skimco's topic in Audio, Backup, Navigation & SYNC
Is the car stopped with the parking brake engaged? -
There isn't one. Ask the dealer to show you where it says $100 deductible. If they persist call Ford.
That's the right rear - the parking brake may only be on the driver's side but I really don't know. I would just get the tool to be safe - it's not that expensive.
I think they may have fixed the headrest issue with the new Explorer where the headrest tilts. At least that's what I thought I read awhile back. I would expect that design to trickle down to other vehicles. Not sure if the 2012 Edge would get it or not but I think it's a possibility. If not the explorer headrests may work.
I'm sure they do since the parking brake is still integrated. Get the more expensive NAPA dedicated Ford tool, not the universal cheap one.
Power Takeoff Unit - it sends power to the rear differential. Find the driveshaft and see where it connects near the engine. That's the PTU.
Factory Code & Keyless entry
akirby replied to Uncle Buck's topic in Alarms, Keyless Entry, Locks & Remote Start
Fuse cover sounds right but I wasn't sure since this has been discussed on numerous vehicles and it's in different places. -
That's what it's made for. It's not designed to be a substitute for a true manual.
Yes it's the same as the ABS sensor. No, it's not part of the powertrain. I think a replacement is only a few hundred bucks. Any dealer could give you a quote over the phone. Not sure if it's a DIY job or not.
