    343
  1. There is no easy way to switch between phones but letting the driver use bluetooth is definitely the best solution. If the passenger gets a call they can always switch phones and put it on the speaker.
  2. Any modification can cause denial of a warranty claim (but not voiding the warranty). But it has to be something related to the failure. If you use a tuner and your radio stops working they can’t deny that claim. But if your transmission fails and it appears to be too much torque and you have a tune they probably won’t cover that.
  3. The best way to describe it is to kick your foot up and touch your shoelaces to the bottom of the bumper on either side of center. At least that always works for me.
  4. Wait - are you getting an AWD Off message or just a general Wrench warning light?
  5. Oh it will probably affect other Edges but the same applies to all of them - once they determine the problem and issue the fix it shouldn't reoccur.
  6. Is the warning light still on when the dealer looks at it? If so they should be able to get a code. If not you might want to try a different dealer.
  7. It's a shame Ford is still having these types of issues on new vehicle launches. But once fixed they shouldn't reoccur.
  8. Nope. Bluetooth only allows one active phone connection at a time.
  9. When I said "raised" I meant "ribbed" <insert joke here>.
  10. Testing insert other media Can't get that to work
  11. Test https://www.youtube.com/watch?v=fJF3MIJYMDI
  12. How exactly are you activating the lock and unlock? To unlock you touch the inside of the door handle. To lock you touch the raised area on top of the door handle. If that's what you're doing, pay attention to where the fob is in relation to the door. If it's in your left pocket and you're facing forward I've had occasions where the fob was too far away from the sensor.
  13. It should do just as well as your Mazda6 which I assume is FWD. There isn’t anything special or different about an Edge vs a Mazda6.
  14. What do you and/or your family members drive now? I live in Atlanta where we shut down the city for an inch of snow, but from what I’ve heard FWD is ok with dedicated winter and/or snow tires. Although AWD will get you out of a few more situations.
  15. No difference in assembly time. The hold up is usually shipping.
  16. And how, exactly, is that Ford’s issue? What do you expect them to do about it?
  17. The active noise cancellation and piped in intake sound are two different things. The first eliminates bad noise from entering the cabin. The second tries to add "good" noise to the cabin.
  18. If it just rubbed the side of the wheel and tire then probably not, but if she hit it hard enough to bend the wheel then I would definitely get it aligned.
  19. The 3.5L V6 was discontinued - only The 2.0L and 2.7L ecoboost are options now (the latter only on the ST). The engine sound is piped in to make it sound sportier. Becoming quite common these days.
  20. Strange considering the engine isn’t new. Hopefully they fix it and you won’t have other problems.
  21. First coat was probably adhesion promoter. Necessary to make the paint stick to plastic.
  22. It's pretty simple, you just turn the vehicle upside down.
  23. Ummm....CDs are digital.
  24. I'd be surprised if it's really turbo lag - ecoboost engines don't normally have any turbo lag because of the small turbos. Delays are usually from the Electronic Throttle Control or the Transmission. The first can be fixed with a tune or something like a JMS PedalMax. Surprised Ford Performance didn't fix it with their tune though so maybe it's something else.
