tpm419419
Everything posted by tpm419419
  1. I had my radio turned down also. That usually goes off when the door is opened. I learned my lesson now. Check and double check. At least it wasn't in a garage
  2. Good to know. Thanks so much. And keep that cold temperature by you!
  3. Yeah I know. Guess I was in a rush and "thought" I pushed the button. Never again
  4. Hello Went into the bowling ally to watch my daughter bowl. Came out to find it running . I thought when you got away from the vehicle with the key fob that it would shut off. I did think I pressed the button but apparently not Car was running for 2 1/2 hours
  5. That's funny. I was doing the same thing. guess you were a 2007 Edge owner also
  6. Firefox gave me trouble also. Had to switch to IE and then it worked fine
  7. Possible because iPhone does not support flash. just guessing. I tried it on Google mapsand it didn't work
  8. On the 2011 with push button start you will see that the key fob has a removable key
  9. Don't let it get to you. you are entitled to express your opinion that is why it's called a "forum". Just as the 2007 model year Edge had issues with things such as a poorly placed hatch release handle (corrected in the 2008 model) and a glossy dash that reflected back at you. I'm sure these little imperfections will be addressed at a later model year. Frustrating that these obvious glitches weren't seen beforehand but it shouldn't take away the enjoyment of the vehicle
  10. Pretty sure it is on the screen to the left of the speedo. Scroll through the options using the 4 way controller on the steering wheel (left side) and you will find it. Good luch
  11. No need to use the keypad. It's great if you do not have your keys on you and need to get into the vehicle
  12. I will try and find the daylight savings time menu and check it. Thanks
  13. I prefer to listen to Fox over CNN but nice job and thank you for the pictures. Well done!
  14. I had used Turtle wax's Tire wax I believe it was called. Can't get it anymore
  15. Hello again Today while driving to the store my "Check Engine" light came on. I restarted the car but still remains on. Anyone experience this yet on their new Edge? Mine only has less than 300 miles on it
  16. For the second time in two weeks the clock in the car has gone off. It was just off an hour and will bet will be back to normal after I get back in it. First time it happened I didn't believe myself that it did it. Strange... I did use a Sync service to get directions (I wonder if that had anything to do with it)
  17. Thank you for sharing that with us. What happens when a Canadian buys a car in the US?
  18. The website shows I have an update to download but I couldn't get it to load to my USB stick
  19. Hello Having the remote start set to automatic for rear defroster and heated seats. Can someone tell me when they should come on? Is it at 32 degrees because here in NY this morning it was 36 and I could have used it Thanks
  20. Tried this myself today without any luck. Resized my pictures but still could not view them
  21. I upgraded from a 2007 as well. The 2011 is much nicer in quality as well as fit and finish. You're going to love it
