tpm419419
Everything posted by tpm419419
  1. I am going tomorrow morning for the update. I'll let you know. Will also ask about the DRL's although not expecting much
  2. I see you have ClsVinyl in your presets. That is all I listen to
  3. Onedge I don't have any solutions for you other than when my car did the Sys Maintenance thing it was only one time and everything afterward worked as it should. You should be thankful your dealer gave you a rental. Is it that you couldn't control the heat/AC settings or were they just being generous Keep us posted and I'm sure we are all hoping for a permanent fix to these problems
  4. Using an iPhone4 I was able to send the directions. It was a bit of a hassle to get the info to show on phone however. Doable though
  5. hello I have had my Edge about 2 months. For the first time I got a white screen after starting the car remotely. I drove a quarter mile, pulled over and turned off the car, opened the door and closed it. I then restarted it and everything was fine. Went another quarter mile or so and turned off the car to pickup my pizza . When I started the car it just had a dark screen for a few seconds and then it went into a Sync maintenance cycle. Not exactly sure what it was doing other than me watching the progress bar go across the screen. All has been fine so far so we shall see
  6. The OEM rubber mats for the 2011 model year has a full 1 piece door to door rear mat that covers everything. Not sure if the 2010 mats are the same or not. I highly recommend these mats
  7. ... and did you check your GPS setting??
  8. To date has anyone been able to get the DRL's turned on??
  9. Foot on the brake and 1 press of the start button works just fine. Haven't tried it your way but seeing as the foot will go on the brake anyway I don't see much of a difference
  10. I am not sure just what problems you guys are having but my iPhone 4 works perfectly with my Edge My Touch. On some occasions I may have to go into the phone settings to have the bluetooth connect but nothing I can't put up with.
  11. Another question Once you get traffic via Sirius will it than display the congested traffic on the screen?
  12. So it is only via Sirius then? I was hoping it would be part of the cars nav itself Thank you
  13. Does the 2011 Edge with nav have real time traffic? and is it automatic or do you have to input something. I tried searching for the answer but couldn't find it Thanks
  14. Ok so taking my daughter to school this morning it happens again. I see the time is 5 hours off. I stop at a light and re check the GPS sync setting and sure enough it was set to off. Switched it to on and so far so good. BUT why with the gps setting set to off why would the time vary so much? Anyhow hopefully it's resolved Thanks
  15. My clock is set to daylight savings and did change this morning. Afterward and after another engine restart the time went off by 4 hours (minutes are always correct). Pretty sure it is synced with GPS but will double check. I'm guessing this will be a tough fix for the shop
  16. Hello For the third time my vehicles time has gone way off course. First time it was off by an hour, couple of days ago it went off by 2 hours. Today I found it off by 4 hours and then again by an hour. Most times when car is restarted it will correct itself. Anyone else have this issue??
  17. I was under the impression that a DVD could be played while the vehicle was in Park. I tried playing Happy Feet this morning but got a disc error. Am I doing something wrong or was I just misinformed? Thanks
  18. Your screen is the same as the Edge. The film designated for the Edge works just fine
  19. I have had 20 plus brand new cars over the years and NEVER had a problem with the dealership prepping the vehicles. I have had black cars that had bad paint but never from a result of it being washed. Common sense tells you to inspect it before signing off on it so if anything should be wrong it could be corrected. You really can't inspect the paint if it's dirty Best of luck with your new rides. Love my 2011 edge
  20. My 2007 Edge never worked on low heat. My 2011 has a very nice low and high setting that actually works
  21. The delay on the touch screen happens more when the screen is cold. Once it warms up you will find the response is better
  22. To start the car click on DOOR LOCK button then hit the 2X button twice (within 5 seconds of each other). So you need to click on a total of 3 times. Door lock, then the 2X button 2 times I had to show my salesman the same thing
