edgemaster
Everything posted by edgemaster
Guys, I have finally decided to replace the spark plugs in my 2007 Edge myself. I seem to remember that I have seen a lengthy post about that but, for the life of me, I can't find it. Can someone please point me to that threat? Thanks, Ed
Temperature gauge erratic/AC does not work right
edgemaster replied to edgemaster's topic in 2007 Edge & MKX
So, I replaced the fan assembly and now the driver-side fan runs again. I disconnected the upper left of the radiator hose and removed the air filter housing. Taking out and replacing the fan assembly took all of 5 minutes. Thanks for all your help, guys. Cheers, Ed -
Never mind. Found the yellow nut just below the lower water hose.
Hi, I need to remove all the coolant in my 2007 Edge. I couldn't find a petcock at all. Do I have to remove the lower water hose to drain? Thanks, Ed
Well, I checked the fan motor for any kind of resistance but it seems to be an open circuit. For good measure, I applied 12 V to the open fan connector and it didn't run. Seems to be solid proof. I'll order a new fan assembly. Thanks for all your help. Ed -
By what are the two fans controlled? I don't mean the controller unit but what event/signal triggers one or the other fan to run or to stop? -
The temp gauge sits mostly straight in the middle of "C" and "H", fan running or not. Only every now and then (maybe once a month) the temp gauge goes to hot and is back to normal after waiting 15 minutes or so. The engine never seems to overheat during that time. Could it be some kind of sensor? Shouldn't the engine check light come on? Or are there failure codes stored inside the OBDII system without that light coming on? -
OK, engine warm, no driver-side fan. Replace the fan assembly? -
Did that! The fan on the driver side does not run, the one on the passenger side does. Are both fans supposed to run when the engine is cold or only when the engine is hot? -
Thanks for the quick response. Is there any way to test that? Would the temp gauge go all the way up without the cooling fan? -
Hi, My wife's 2007 Edge acts up. The AC seems to work only at times and the temp gauge shows all kinds of temperatures. I had it tested and the egine temp is okay, there's enough coolant in the system, everything seems to be fine. Could it be some kind of sensor? Shouldn't the engine check light come on? Or are there failure codes stored inside the OBDII system without that light coming on? Where should I start searching? Any advice would be greatly appreciated. Ed
Replacing headlights
edgemaster replied to edgemaster's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
They are foggy on the inside. -
Hi, My wife's 2007 Edge headlight lenses are kind of foggy in some spots.. I polished the outside real smooth but it seems to be on the inside. Is there any way to replace the plastic cover (or take them off and polish the inside) or do I have to replace the complete units? Seems like overkill to me. Thanks, Ed Sorry about that typo in the headline. Couldn't figure out how to correct that.
Interior airflow almost non existant
edgemaster replied to edgemaster's topic in Interior, A.C., Heat, Interior Trim
Thanks for the details, I appreciate that. Ed -
Geez, where are all the Edge experts? Is there nobody who can tell me where the air inlet for the interior airflow is? Ed -
Maybe the air inlet in the engine compartment is blocked with leaves, etc. Can yo tell me where this inlet is located? Thanks, Ed -
My wife just had an oil change done and they told her that her 2007 Edge had the same inside tire wear problem. I can understand that the front wheels might get out of whack every now and then but all four wheels? Is that even possible? What should a decent 4 wheel alignment cost anyway? Thanks, Ed
This is the stainless steel protector wlepse has seen on e-bay: http://www.aliexpres.../573800151.html Looks nice but the shipping charge seems a bit excessive. Ed
Hi, Can someone tell whether over-the-door handles can be installed in a 2007 Edge? We used to have them in our Escape, they helped tremendously getting in and out of a seat when one has leg problems. Thanks, Ed
Windshield rubber strip question
Can't it just be pushed down where it came from? -
It goes all across the width of the windshield. -
Guys, The other day I noticed that there is a soft rubber strip wiggling its way out of where the windshield and the dashboard meet. Can I rip it completely out or should I try to push it back in?
