candurin
Everything posted by candurin
And if you have an SE or an edge without automatic climate: Manual climate control For hot weather conditions: The climate control system will be set to MAX A/C. For cold weather conditions: The climate control system will be set to provide maximum heating in (floor/defrost) mode. Rear defrost/heated mirrors (if equipped) will be activated. For moderate weather conditions: The interior cabin will be heated, cooled or off, based upon the previous operating state (last ignition-on cycle). Rear defrost/heated mirrors (if equipped) will be deactivated.
The conditions of the auto climate do change with outside temperature. The owners manual has a full explanation: Automatic climate control For hot weather conditions: The interior cabin will be set to 72°F (22°C). The cooled seats (if equipped and if the feature is selected to AUTO in the message center) will be set to high. For cold weather conditions: The interior cabin will be set to 72°F (22°C). The heated seats (if equipped and if the feature is selected to AUTO in the message center) will be set to high. Rear defrost/heated mirrors (if equipped) will be activated. For moderate weather conditions: The interior cabin will be heated, cooled, or off, based upon the previous operating state (last ignition-on cycle). Heated/cooled seats (if equipped) will be deactivated. Rear defrost/heated mirrors (if equipped) will be deactivated.
Brightest LEDs...
candurin replied to candurin's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Yes, I got the HP24. They are considerably brighter than the vleds. I waited until they had a 20% off and snagged them for $40 or so. I'm very happy with them. They do seem the best built (aluminum). I'll report back if they ever fail. -
Brightest LEDs...
Nope. Zero issues with the new ones. My original VLED ones went erratic, the eBay ones I then tried eventually failed (never erratic, but the Amber LEDs went on one bulb). I have high hopes these will last. -
2012 SEL LED Headlights
candurin replied to kshawks's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Let's not forget 10k or higher purple light! I smack myself and curse the idiot who put those in. I shudder when I think of those morons driving at night on wet roads. They would get more light output from the "flashlight" feature on their smartphones. -
Brightest LEDs...
Don't forget diode dynamics. Just picked up my replacement switchbacks from them and couldn't be happier. -
That's a shame rusty, the dealer should be able to bill you a half hour for the activation. You can also see if a local pep boys, Firestone etc has the IDS tool (many service centers do). As far as the key goes, try lowes or a local locksmith. It's an easy key to cut. Just tell the Home Depot manager that you assume all responsibility. Have you tried Walmart?
The "stone" color is correct. I was suprised when I got my edge, too.
Ultra HID Kit -- DDM Tuning
candurin replied to Cellbine's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
CB, it looks like TRS pulled their harness only auctions from eBay, but the link Perf supplied for the harness is the exact one you want. It's a good harness and worth the money. The eBay link you posted seems ok, but the wires seen like thin gauge. I had tried the capacitors when I had my DDM installed (for three weeks, when I first got my edge), but they didn't provide any performance enhancement at all.- 35 replies
- HID Kit
- Ultra HID Kit
Text messages with MFT ( iphone 6)
candurin replied to Tjames557's topic in Audio, Backup, Navigation & SYNC
Make sure you turn on "show notifications" under settings > Bluetooth > sync You might have to disconnect and reconnect your phone in the MFT -
Sirius will transfer to a new radio.
airbag warning light stays on
candurin replied to lpgao's topic in Alarms, Keyless Entry, Locks & Remote Start
That sounds like a bunch of issues all at once. You can always reset the system (I simply pull the power to the fuse box under the steering wheel to the left of the brake pedal) and see if that works. If not, that is likely worth a trip to the dealer. -
candurin replied to WWWPerfA_ZN0W's topic in Accessories & Modifications
Added a "proxy" component for my edge. Since I added the cellular remote access for my edge, I realized this still wouldn't solve my issues with my car being hot or cold at home (always garaged). So, I added the MyQ remote garage door capabilities to our Chamberlain opener (2003 model). Now I can open the garage door and safely start my Edge, both from my phone. -
CB, Just be cautious with that wire harness. Many of us have had the harness melt after just a few uses (myself included), albeit that was with a 55w kit. You can always replace the harness with one from TRS (I think it can be had for $15-20 on eBay), which is of a much higher build quality.- 35 replies
- HID Kit
- Ultra HID Kit
It's that easy (disclaimer: the two little plastic plug/screws that hold the side panel to the floor pan take the longest to remove). My install took me 30 minutes. Just make sure you have a t50 torx bit. I had to go buy this one: http://www.homedepot.com/p/Husky-T50-Torx-3-8-in-Drive-Bit-Socket-H3DHBST50/202913549/ The only caveat would be if your edge does not include the wire harness for the hood switch. But I've seen those on eBay as well. You probably have it though.
