gjb89
Everything posted by gjb89
2016 Edge Sport - Tail Light Lens Tint Options?
gjb89 replied to roots57's topic in Accessories & Modifications
I have the Lamin-X fronts and used a roll of theirs todo the rear lights. Very subtle and barely dimmed the output. -
Aftermarket LED driving lights are garbage especially when they are in a halogen projector. I would go for the H9 upgrade.
I can't see a throttle body spacer being beneficial on any modern day engine besides giving the user an injection or reference point.
Will the new intake replace the accordion intake piping?
I haven't run it myself. I know that was an option.
Can't remove the grille without removing the bumper cover.... ive had the front end off 4 times.
There is also an aggressive with firm shifts too.
I went the drive bright ones also. No comaplaints yet
I'm sure you will get a bulb out warning, I disabled the bulb out notification with forscan instead of using resistors. The H15 I purchased were from iJDmtoy.com. There is a picture above with the license plate lit with the leds. They have about the same output as the OEM ones just a different color.
Rear one is mounted by double sided tape and two pressure clips, comes right off with a trim tool. The only way to remove the front one is to take of he the whole front bumper cover/grille.
The exterior of the pan should be plastic with a waffle pattern and a yellow drain plug. Kinda a similar looking to the f150's (3rd picture) https://www.edmunds.com/ford/f-150/2015/long-term-road-test/2015-ford-f-150-easy-diy-oil-change-holds-a-minefield-of-potential-screw-ups.html
I'm not sure on the color. I had to take mine in because the factory did a poor job on applying the liquid gasket causing a minor leak.
Mine was sealed from the factory, no gasket.
Give me till the weekend and I'll get something up on YouTube.
I would agree most people do not care what they put in their cars and trucks. Whatever is the most convenient.
Odd smell from AC vents during hard acceleration
gjb89 replied to gg2017's topic in Recalls, TSBs & Warranty
Blow off valve is on the intake not the exhaust. Also the OEM blow off valve vents back into the system, not the atmosphere. -
There are other members that have complaints about smelling the exhaust, I have yet to smell anything. I wonder if a coating of tail pipe sealer on the connection on the cat-back section would help. -
Have to take the whole front end off. Pain in the ass.
delete
Ultra HID Kit -- DDM Tuning
gjb89 replied to Cellbine's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
More then likely.- 35 replies
- HID Kit
- Ultra HID Kit
I would be very surprised if you find a rental that's a Sport. Doesn't seem very cost effective for a rental company.
Thank you.
