edgeidiot
Everything posted by edgeidiot
Greatest.thing since sliced bread. Just buy it.
I would suggest tires classed as touring or luxury. These tires provide a luxurious ride and since the speed rating is lower than sport tires, the tires will last a lot longer.
Do you have an extended warranty? Having worked in an auto repair facility, I have seen too many cases where we would refuse to change the ATF (we did not have the flush machine) because of the interval between changes. I am old school. I changed the engine oil at 1K and transmission fluid at 15K. I would have changed the rear differential at 5K, but my Edge is FWD, and I bought the extended warranty.
AWD Malfunction Warning After Low Tire
edgeidiot replied to w102acd's topic in All Wheel Drive (AWD)
Concerning the original TPMS warning, did you determine why one tire suddenly lost ten psi? I am trying to understand what could cause this. As little as a tiny leak in the tire or the wheel should have caused the tire to completely deflate in a week. If the valve stem was leaking, the TPMS occasionally should have measured that the pressure was low. Was it parked in an airport parking lot where someone depressed the value stem? What was the pressure for the other three? -
Dash phone mount location 2022 Edge
edgeidiot replied to tahoemike's topic in Accessories & Modifications
I just found out that there is an updated version using Magsafe: 2019, 2020, 2021, 2022, 2023, 2024 Ford Edge Phone wireless charging phone mount | eBay -
I found this mount on ebay. It was made for and fits in the cubby hole. 2019, 2020, 2021, 2022, 2023, 2024 Ford Edge Phone mount black | eBay -
I noticed that you have Kelly Edge tires. Was it a coincidence?
There is a difference in the circumference (height) of these sizes. Aspect ratio is the percentage of the sidewall versus the tire width. Rim diameter only means that a tire will fit the rim. In the specific case above, the 275's are 8 mm taller, 10 mm wider and will revolve 7 times less per mile which will cause a slight speedometer error.
I found the replacement part numbers: Left KT4Z-16103-A Right KT4Z-16102-A Around $70 each side at your favorite online Ford parts dealer.
Doors Intelligent Access
edgeidiot replied to Mickalo's topic in Alarms, Keyless Entry, Locks & Remote Start
This happens on my 2020 Edge once in a awhile. When your battery reaches a status of low charge, you should see a message on your SYNC3 screen. Normally, the accessories (like the SYNC3 system) remain on until you open a door. In the low charge mode, the accessories turn off when the engine is turned off. Are you experiencing the Stop/Start function is also not working? To reset, all you need to do is to recharge your battery. -
I have added the hood insulation pad. It is a direct fit for my 2020. Their website shows that it fits all 2020 models (I do not know about the other years, but unless they also deleted the grommet holes, I would think it fits any model of this generation.) The part number is KT42Z16738B. The grommets are included. Should be $100. I should have added that the installation takes no time.
edgeidiot replied to WWWPerfA_ZN0W's topic in Accessories & Modifications
Been looking for a cell phone mount and came across this. What do you think? 2019, 2020, 2021, 2022, 2023, 2024 Ford Edge Phone mount black | eBay -
Groovy! Remember the Goodyear Polyglas GT? I love a challenge. Firestone makes a P245/60R18 All Terrain tire with OWL (outline white letters). I will take my tie-dye shirt with me on my way to the social security office.
- 26 replies
- 2
- tires
- white letter
(and 2 more)
In the fine print,
Are you trying to find a used set of wheels? Gosh, I would think that it would be like finding a needle in a haystack. I don't think Ford sold that many Edge's with this package. Suggest contacting a junkyard to see if they would do country-wide search for the wheels you want. They will need the year and model trim for the vehicle. fordauthority.com has a page that shows by year what wheels were available. If that fails, you may have to order from the dealer (search for the Ford dealers listed in this forum that sell parts at prices lower than other dealers.) I did find a site that says they sell only OEM rims: Premium Factory OEM Wheels | Detroit Wheel and Tire. Hard to match the wheel above versus the pictures on their site. By my untrained eye, the closest one runs $2,700 for a set of four and I am not sure if that includes shipping. See if they will give you a discount for exchanging your old rims. I wish you the best of luck.
2020 SEL - Where to penetrate the firewall?
edgeidiot replied to GhostRider's topic in Accessories & Modifications
You should be able to use the search box to find previous posts about installing a Dash Cam. I don't remember that anyone mentioned piercing the firewall. There is a fuse box in the cabin. -
Yes, I am the old tire salesman. The closest match to the diameter of the 265/40R21 currently on your vehicle in an 18-inch rim is a 245/60R18 which is coincidentally the stock tire on other Edge trims. You did not say whether you are going to buy OEM or aftermarket rims. OEM Rims should cost around $200 and up at online Ford dealers (ymmv). I have attached the nerd specs. Doc133.pdf
Yes, I can see that they fit. What I notice is that your new tire (315/35R20) is two inches less in diameter than the old tire (255/50R19.) It may cause increased wear because of the reduced diameter and a greater speedometer error.
I know this is not the answer you are looking for but this is the answer that I can give you is from experience as a tire salesman. There is no guide that I know of correctly fitting wider tires to a vehicle. Purely, wider tires come with increased circumference. It is purely guesswork to see if a tire will fit. There is a concept of lower profile tires which is called plus one/two/three. Basically, you can get a higher sized rim but must keep the overall circumference of the tire the same as the OEM tire. Circumference is the most important tire measurement as the speedometer error is less and the wheel should fit in the wheel well. The OEM tire size is 265/40R21 if you have the upgraded package. The circumference is 29.35". I found a 24-inch tire which has a circumference of 29.2 inches with a profile of 25 (265/25R24). I would guess that you need to add at least $1600 for the rims. Obviously, the demand for that size of tire is not high and I found only three available manufacturers making that size (Nexen, Nitto and Lionheart.) I would guess that those tires would have a life span of about a week. In a 22-inch rim size, there is a tire with a circumference of 29.3". The tire size is 265/35R22. There are a lot of tires available in that size and most should have a better life span. Unfortunately, all of these tires have a width of around 10.4 inches.
2019 edge st has 265/40r21 can I run 265/50r20?
edgeidiot replied to joryb's topic in Wheels & Tires
I think that you want to put the 20" rims back on your Edge, replacing the OEM tire size which is 245/50R20 with tires you found at a dealer with(24,26,27)(195,190,182)265/50R20 sized tires. I used to sell tires and here is the scoop. The 265/50R20 tires have a diameter of 30.5 inches and width of 10.4 inches. The 245/50R20 tires have a diameter of 29.7 inches and width of 9.6 inches. The 265/40R21 tires have a diameter of 29.3 inches and width of 10.4 inches. If someone wanted to do this in my old shop, we would have to mount the new tires on the wheels and see if they fit. It is really anybody's guess. Changing tire size has two side effects. Vehicles are tuned for ride quality with the OEM tire size. Changing the tire size will have an negative effect on ride quality. Also, since the number of revolutions of the new tires will not be same as the OEM tires, your speedometer will not reflect the correct speed. -
When I bought my extended warranty, I did a search to find other posts already made here. They suggested using dealerships that sell Ford Factory extended warranties online. The price that you quoted was probably from a local Ford dealer as I think you could get that warranty for around $1,300 (depending on your state of residence) and there is a code that gives you an additional discount of $365 for payment in full at Ziegler Ford which is where I bought mine.
If I were in the market for a used AWD and the tires on the vehicle are mismatched it would raise some concerns for me. There is a lot of debate surrounding whether having mismatched tires can cause premature wear on the drivetrain of an AWD vehicle. There is even debate concerning whether to replace the entire set if one tire needs to be replaced due to a blowout or other damage, as AWD vehicles require tires with the same circumference. I am guessing that you want good wet and dry traction and a long period until replacement is necessary. Have you considered selecting the OEM Michelin tires? The ride quality of the Edge is exceptional, and the OEM Michelin tires are a part of the ride quality system.
R&R Liftgate Finish Panel (Rear) KT4Z5843401A
edgeidiot replied to edgeidiot's topic in Exterior & Body
Thank you very much! -
I recently scratched my Liftgate Finish Panel on my 2020 Edge SE and purchased a replacement. Has anyone here replaced theirs before? Any tips or advice would be greatly appreciated.
I have the same problem with my 2020. Unless I drive for at least an hour, the battery doesn't recharge enough for the auto start/stop feature to work. Short trips drain it so much that even the door lock system will eventually stop working on every door except the drivers. I had to buy a battery charger. And why is the battery located where you cannot attach a regular cable to the negative post?
