Depiry
Everything posted by Depiry
Rear brake seized, continuing problems
Depiry replied to alhope34's topic in Brakes, Chassis & Suspension
Replace Brake hose,a bad one will stop fluid from returning and cause caliper drag or lockup,Marty -
Passenger Mirror Busted
Depiry replied to inasser's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
I just replaced the driver side mirror,while sitting in the car someone drove by like he was on Daytona and mirror to mirror,he destroyed the mirror completly thru one of my accounts who runs 211 Ford Escape hybrids as Taxis the mirror list $321 cost $200 and was a 10 minute replacement,I have to remove the cap to paint it but the color is dark blue and can wait until warmer weather to do so ,Marty -
Tail light bulbs
Depiry replied to igcitng's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Thanks,Marty -
LV is the correct Trans Fluid,after draining thru plug on bottom,5 Qts is refill, CAREFUL which plug one is for final drive <Marty
Tail light bulbs
Dingo,Do you know of any Led replacements for # 3157 tailight lamps,to eliminate socket burn, good quality and brightness,I have a 2010 and want to put in 2012 tailamps using LED's with a resistor for the flash speed, Thanks Marty -
LED Turn/Tail/Reverse Lights
Depiry replied to Subzero's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Turn/Stop/Tailight is 3157 lamp. Any recommendations for an LED replacement?? -
I just replaced front centric rotors and Bendix CT3 ceramic pads WORST stopping combo I ever had, with EBC Red Stuff Front and Rear, with Motorcraft rotors front, Initial useage fells great,Friction coefficiant .5 or GG, Great so far ,Marty
Rear brake pads, what is everyone using?
Depiry replied to surferd15's topic in Brakes, Chassis & Suspension
I would use the same pad front nad rear to keep the fricton level the same,cost for braking is not a consideration when safety is prime, I just replaced front centric rotors and Bendix CT3 ceramic pads WORST stopping combo I ever had, with EBC Red Stuff Front and Rear, with Motorcraft rotors front, Initial useage fells great,Friction coefficiant .5 or GG, Great so far ,Marty -
Tail light bulbs
LED'S would definately cure the heat problem,but you wil have to use a resistor in the circuit to keep the flasher rate as normal,Marty -
I have a 2010 limited wit factory plastic wheel covers,between the spokes the covers have dirt or oxidation ,what should be use to remove dirt,thanks Marty
Try replacing the sensors,Marty
The EBC will give shorter stopping distances,check their Website, I am waiting for their delivery later this week,Marty
Mothers California Gold Water Spot Remover for Glass
Depiry replied to icee's topic in Appearance - Detailing, Wash & Wax
Using 3M clay bar with Quik wax works Great,Marty- 6 replies
- glass
- water spots
EBC REAR BRAKE PAD SET - EBC REDSTUFF 3000 - CERAMIC 2010 FORD EDGE LIMITED 6 CYL 3.5L -- EBC REDSTUFF BRAKE PADS, CERAMIC, 2-WHEEL SET Amazing stopping power is guaranteed with EBC Redstuff Brake Pad Set Series. Especially engineered for high-horse power imports, muscle cars, and prestige European cars, this product line has been proven to increase stopping power by a whopping 30 percent! Featuring a Kevlar-based compound that is enhanced with ceramic particles, Redstuff Pads have a higher-than-OEM heat threshold for resistance against brake fade, incredible bite from cold, a low dust rating, and long product life. All of these features make Redstuff Pads perfect for repeated heavy braking during fast street use. With EBC Redstuff Brake Pads, you have full confidence in the braking power of your vehicle. Features: Asbestos-free Made from a innovative blend of Kevlar fibers and enhanced ceramic particles Produces 60-90 percent less dust than OE pads Brake bite from cold is as good as OE or better Brake performance only increases as the pads heat up Built with shims, slots, and chamfers for silent braking Coated with Brake-In compound for faster break-in and greater initial braking effect Install these brake pads with the help of EBC's instructional video P/N E35DVD083 (sold separately). Location: Rear Material: Ceramic Series: EBC Redstuff 3000 Quantity Sold: 2-wheel set Warranty: 12-month or 10,000-mile EBC warranty excluding wear and tear or race use Part Number: E35DP31795C Availability: In Stock This Product Fits the Following Vehicles: 2010 Ford Edge Limited 6 Cyl 3.5L
The letters refer to cold/hot cf's
does any one know the code letters on the pads EE.FF,GG??I have the chart showing the CF's to the letters, but will be away until the 27th an could try to post then,Marty
cold bite should be good I have Centric rotors and Bendix CT3 Ceramics on the front rated FF ,They are coming off for Motorcraft rotors and EBC Red Stuff,which comes coated with break in compound,Kevlar ,ceramic Low dust Long life, My VW Touareg Has Brembo Pagid Pads With GG Rating ,Good bite hot or cold,Marty
EBC red stuff has a .5 coefficient of friction,GG rating highest around most others are FF lower rated,Marty I am ordering a full set shortly.
What kind of power steering fluid goes in '08 AWD Edge?
Depiry replied to Joab Dellinger's topic in All Wheel Drive (AWD)
Mercon V is correct for the power steering according to the owners manual,Marty Mercon LV is used in the Transmission. -
Ford Edge (V-6) The stylish lines of this crossover SUV might catch your eye, but we suggest that you keep on looking. In our testing of the V-6 all-wheel drive version, we found a jittery ride, pronounced road noise, and distracting controls, especially with the complicated and unintuitive MyFord Touch infotainment system. And in our annual survey of subscribers, it had much-worse-than-average reliability. There is also a turbo four-cylinder engine that works well and gets better fuel economy, but it can't be paired with all-wheel drive. For about the same price, better alternatives include the Toyota Highlander, Nissan Murano, and Mazda CX-9
Bendix CT-3 ceramic Pads are friction rated FF Akebono ceramicPads are friction rated FF Raybestos ceramic are friction FF at the low end of FF EBC ceramic red stuff is friction rated GG Marty What are the code letters on the OE Motorcraft??
LED Resistors
Depiry replied to kshawks's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
The flasher is load specific,if a lamp is out it flashes rapidly,a led lamp without a resistor is like having a lamp out,they need load resistors for both front and rear to match the lamp loads,Marty- 1 reply
Only use the specified fluid not some generic brand that they put a small bottle of additive to bring it to mfgr specs,How much old fluid is recirculated into your trans lines ,that is left from previous usage?? Marty
Which lamps(Led) did you use and what source did you get them from,TIA Marty
